Текущее время: 27 ноя 2026, 01:21
 Заголовок сообщения: Asus UM5401QA - OLED191W (UM5401QAB R3.1) NOT negociating 20V and works only on battery
СообщениеДобавлено: 17 июл 2026, 11:50
Hello,
I got this Asus UM5401QA - OLED191W with motherboard UM5401QAB R3.1 that it's working perfectly on battery.
If i plug in any USB-C charger it will stuck at 5V and laptop it won't start or charger the battery.
I checked and both USB-C ports are ok. I replaced IT8853FN128 with 2x new, i replaced IT5125VG-128 and laptop reflashed it automatically (i read it with SUCCESSOR and compared is identical with new firmware). I also reflash BIOS with latest from asus.
Any other idea please? Thank you.
 Заголовок сообщения: Re: Asus UM5401QA - OLED191W (UM5401QAB R3.1) NOT negociating 20V and works only on battery
СообщениеДобавлено: 17 июл 2026, 16:44
возможно их надо прошить ещё?
СообщениеДобавлено: 17 июл 2026, 17:33
Any idea how? :) and what to flash. I can’t find any dump.
СообщениеДобавлено: 18 июл 2026, 02:08
It has 64 KB of internal EEPROM. However, there is no software. The manufacturer does not provide it.
Check pins cc1 and cc2 with an oscilloscope. If you see a continuous signal, that means there is no communication.
DIACOM Computer Service : CEO, Senior Technician, Teacher
YouTube Channel: CRM
СообщениеДобавлено: 18 июл 2026, 02:33
How did you check that?
What is the resistance of CC1 to GND? CC2 to GND? On each type-c port.
СообщениеДобавлено: 18 июл 2026, 10:40
ставите обратно родной контроллер type-c ite (если он не убит по питанию) и наследником пытаетесь вычитать прошивку ite по i2c.
я бы начал с этого.
СообщениеДобавлено: 18 июл 2026, 14:10
DanqeR
Looking in main bios!?
Use ECFinder/Hxd(for search ->ITE8850-PD)
СообщениеДобавлено: 21 июл 2026, 12:11
Thank you for answers.
So... I did some more in depth checks and: the CC1/2(A/B) rails look fine, in the 15-16Mohm range, normal reverse polarization drops (~0.5V), traced continuity from the connectors to the chips. There is one interesting aspect, I don't exactly know if it's related to the defect but without battery, the 1.8v and 3.3V rails pulse at about 12Hz and they stay solid with the battery connected. Also, without battery, the EC SPI is read in short bursts at each cycle but the data time on the DO is shorter that the CLK burst. With the battery connected, it looks like doing a complete read on the EC ROM. The 12Hz rail pulsing is not in equal bursts. There are about five short pulses followed by one long pulse and it repeats the pattern perfectly. The precise repetition tells me that it should not be a physical issue like a shot but maybe a firmware or data exchange issue. This laptop should negotiate 20V without battery, right?
Only thing i can find is "ITE8226-EC"
В этой теме нет новых непрочитанных сообщений. Sarphie Radeon RX 560 Pulse 4GB (works only 3GB)
Micchaleq
27 июл 2018, 12:19
kolyandex Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gainward RTX3070 only works with AMD Mainboard/CPU
Dance0fArrows
2174
09 сен 2023, 23:30
Opacky Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. EVGA RTX 3070 — artifacts / wrong colors only in Windows, MATS and MODS pass, GPU reball did not help
spyke11
19 мар 2026, 17:50
Piglet666 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. E5-571 (LA-B161P) not charging not switch with battery
erdi34
06 окт 2018, 19:25
t.tashbaev Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. UN5401Q (UM5401QAB R3.1) Не включается
Gashan4ik91
14
1504
06 июл 2025, 15:16
saiken2006 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 95
