hello masters. I have an asus TUF gaming a520m-plus II PC motherboard on my bench that came in with no EN voltage on vcore. after I fix that the board now is working but with stuck cpu clock. I never fix this issue on pc motherboard before. can someone gime me a path to verify? below I share some pictures to clarify you. ty
cpu clock on w10 task managerhttps://streamable.com/wzvtgcmotherboard takes much time even to load asus bios firmware. I've already flashed the bios firmware but did not solve this problem.
how vrm circuit is behaving ...
https://streamable.com/io8qsh
