Текущее время: 26 июн 2024, 16:23
 Заголовок сообщения: A1286 logic board issue
СообщениеДобавлено: 27 июн 2013, 11:07
Hy All,
I have an a1286 logic board (820-2330-A) and this is faulty (water damage). When I try to turn on, it turn on, but screen is black and logic board gives a beep code (3 long tones, 3 short tones, 3 long tones). I find that it means: Firmware restoration from CD in process. But firmware restoration CD isn't for this model.
Has somebody any idea?
Thank you!
 Заголовок сообщения: Re: A1286 logic board issue
СообщениеДобавлено: 27 июн 2013, 12:37
Hi
Check all the board for the oxides damage.
Then if you find some damaged signal or power lines-reair it.
If no, clean it well and I thing everything will be OK. :-):
СообщениеДобавлено: 28 июн 2013, 12:26
Duiesel писал(а):
Hi
Hi Duiesel,
I've cleaned the oxides damage, but it hasn't been good yet. I think it may be a bios problem, or not? I don't understand the code, because Apple didin't present firmware restoration CD for this type. But what does the code mean?
СообщениеДобавлено: 30 июн 2013, 02:43
First of all, double check the board for oxidation.
I use these two:
http://www.radioshack.com/product/index ... Id=2104746
http://www.yaotek.com/store/ProClean-Fl ... P1908.aspx
Weird enough, these two in combo proved to clean off oxidation pretty well.
Then, try to read the EFI chip (I believe it's SST25VF032B) with a programmer (SP8-B) and verify it against a working dump (bunch of them here, ex: viewtopic.php?f=51&t=6547&p=65107&hilit=%2A820+2330+A%2A#p65107).
PS: Don't forget to change the board code in the EFI hex dump to yours before erasing and programming :)) (It's all the way at the end of the dump, the 17 digit ID)
Good luck!
СообщениеДобавлено: 10 июл 2013, 11:12
I use these two:
Good luck!
Thank you! I checked these cleaners, but I can't buy in my country, I can order abroad these, but it will be very expensive. :(
I use PCC and isopropil alcohol for cleaning, I think these are good alternatives for yours.
So I have cleaned the board more times, but nothing happened. After I bought SPI programmer and I tried rewrite the EFI bios, but logic board doesn't work with the new dump. This is a mysterious fault for me. Maybe are the GPU, CPU or integrated RAM wrong?
СообщениеДобавлено: 14 сен 2013, 23:20
Maybe there is any other stange behave?
СообщениеДобавлено: 03 окт 2013, 10:41
Попробуйте прошивку для восстановления CD здесь:
http://support.apple.com/kb/HT2213
Имеет ли значение, если оно имеет Рами? звуковой картины что-то изменить?
Напряжение 3,4 V на флэш SST25VF ... ?
В этой теме нет новых непрочитанных сообщений. LOGIC T2P (MTK MT8321 MT8311) L706 V0.3 - LOGIC Mobility T2P tablet
в форуме Схемы планшетных компьютеров | Tablet PC schematics
kotnatan
28 май 2019, 19:27
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Samsung keyboard maping issue NP450R5E (ramos) keyboard maping issue
в форуме Samsung
minanpil13
03 апр 2019, 10:30
minanpil13 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Apple MacBook Pro 15 Retina 2012 (logic board 820-3332-a) no charging
в форуме Apple
b4ndit
15 мар 2015, 21:34
massino Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Продам Apple iMac 21.5" A1418 Mid 2014 Logic Board 8GB w/ i5-4260U 1.4Ghz
DoctorJO
24 ноя 2018, 02:56
DoctorJO Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A1369 (820-3023) Не температуры от датчика Logic Board
в форуме Apple
klokol
30 дек 2019, 20:36
Сейчас этот форум просматривают: z_west и гости: 13
