Текущее время: 29 сен 2024, 01:57
ayad
Заголовок сообщения: dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work Добавлено: 08 окт 2013, 08:35 |
Зарегистрирован: 11 май 2013, 10:38 Наличности на руках: 1,507.22
Hi all , I have dell vostro 1015 it dose not work , the +3.3V_ALW is ok , but +5V_SUS is absence , please any one could tell me why . What different between ALW , SUS signals , and what S3 , S5 meaning .............
mashder
Заголовок сообщения: Re: dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work Добавлено: 08 окт 2013, 10:50 |
Зарегистрирован: 27 фев 2012, 19:06 Наличности на руках: 601.50
Сообщения: 418 Откуда: Israel
ayad писал(а): Hi all , I have dell vostro 1015 it dose not work , the +3.3V_ALW is ok , but +5V_SUS is absence , please any one could tell me why . What different between ALW , SUS signals , and what S3 , S5 meaning ............. "doesn't work" is not enough in order to understand what is goin on. Please give more details what is going on when you push the power batton, current consuption before and after pushing the power button, fan behavior, etc...
_________________ Don't be afraid of big spendings, be afraid of small income:)
mashder
Заголовок сообщения: Re: dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work Добавлено: 08 окт 2013, 12:24 |
ayad писал(а): any led dose not glow , fan dose not move ..... You didn't tell regarding power consumption. Any way, if you have 3.3 v you would probably reflash the bios.
mashder
Заголовок сообщения: Re: dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work Добавлено: 08 окт 2013, 17:49 |
ayad писал(а): I did but nothing change Did you check with scope whether or not there is communication between BIOS chip and multicontroller? What multicontroller is there?
mashder
Заголовок сообщения: Re: dell vostro 1015 (DAVM9MMB6G0 REV G) Dose not work Добавлено: 12 окт 2013, 19:29 |
ayad писал(а): I have solved that problem , I have replace XTAL near KBC , thanks to all.......... Well done!
