Текущее время: 25 июн 2024, 10:17
Mirco
Заголовок сообщения: Re: Toshiba Portege Z930-B112 (FAU2SY1) код ошибки? ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 11 окт 2013, 01:45 |
Зарегистрирован: 16 сен 2011, 13:35 Наличности на руках: 14.07 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 258 Откуда: Ивано-Франковск
разбирайся..вот коды ошибок Тощиб
Diagnostic codes for the 2400 and 1400 series are the same, so the following should help you diagnose the fault.
The start of the diagnostic code flash is signified by the light not flashing for two seconds. A '1' is signified by the light being illuminated for one second, and a '0' is signified by the light being illuminated for half a second. The interval between data bits is signified by the light not being illuminated for half a second. Error codes are read from the least significant bit to the most significant bit (backwards), and are read in hex. For example, error code 12h would be signified by: Off for two seconds (Start) 0, 1, 0, 0, 1, 0, 0, 0.
Error codes beginning with 1*h relate to the power adapter, and signify that it is not connected. These error codes run between 0x10 and 0x1F
Error codes beginning with 2*h relate to the 1st battery, and signify that it is not connected. These error codes run between 0x20 and 0x2F
Error codes beginning with 3*h relate to the 2nd battery, and signify that it is not connected. These error codes run between 0x30 and 0x3F
The following error codes are relevant if the AC adapter is connected. These error codes range from 0x40 to 0xDF and can signify a problem with the following:
4*h S3V output 5*h C5V output 6*h C3V output 7*h PPV output 8*h PGV output 9*h 1R5-E1V output A*h 1R8-E1V output B*h 2R5-B2V output C*h 1R25-E1V output D*h 2R5-E2V output E*h F*h
While the above should be enough to let you know what is going on, these may be necessary if you wish to diagnose and repair the problem yourself.
Full error codes are as follows:
10h AC Adaptor output voltage is more than 16.5 V. 11h Common Dock output voltage is more than 16.5 V. 12h Current from the DC power supply is more than the limit (6.16 A). 13h Current from the DC power supply is more than the limit (0.5 A) when there is no load. 14h Current sensing IC is not normal. 20h Main battery voltage is over 13.46V. (Not supported) 21h Main battery charge current is more than 5.06 A. 22h Main battery discharge current is more than 0.5 A when there is no load. 23h Main battery charge current is more than 2.70 A when DC IN direct charge is off. 24h Current sensing IC is not normal. 25h Main battery charge current is more than 0.3A when the battery isn't being charged. 40h S3V voltage is under or equal to 3.14V. (On/Off) 45h S3V voltage is under or equal to 3.14V. (Staring) 50h C5V voltage is over 6.00V. 51h C5V voltage is under or equal to 4.50V when the computer is powered on. 52h C5V voltage is under or equal to 4.50V when the computer is booting up. 53h C5V voltage is abnormal when the computer is suspended. 54h C5V voltage is abnormal when the computer shuts down. 55h C5V voltage is less than 4.50V when the computer is starting. 60h C3V voltage is over 3.96V. 61h C3V voltage is under or equal to 2.81V when the computer is powered on. 62h C3V voltage is under or equal to 2.81V when the computer is booting up. 63h C3V voltage is abnormal when the computer is suspended. 64h C3V voltage is abnormal when the computer shuts down. 65h C3V voltage is less than 2.81V when the computer is starting. 70h PPV voltage is over 1.56V. 71h PPV voltage is under or equal to 0.68V when the computer is powered on. 72h PPV voltage is under or equal to 0.68V when the computer is booting up. 73h PPV voltage is over or equal to 0.68V when the computer is powered off. 80h BGV voltage is over 2.28V. 81h BGV voltage is under or equal to 1.53V when the computer is powered on. 82h BGV voltage is under or equal to 1.53V when the computer is booting up. 83h BGV voltage is over or equal to 1.53V when the computer is powered off. 84h BGV voltage is abnormal when the computer is suspended or over 1.53V when the computer is suspended. Also, BGV voltage is more than 1.53V when the power off. 90h 1R5-E1V voltage is more than 1.80V when the computer is powered on or off. 91h 1R5-E1V voltage is not more than 1.275V when the computer is powered on. 92h 1R5-E1V voltage is not more than 1.275V when the computer is booting up. 93h 1R5-E1V voltage is not less than 1.275V when the computer is powered off. 94h 1R5-E1V voltage is not more than 1.275V when the computer is suspended. A0h 1R8-E1V voltage is more than 2.16V when the computer is powered on or off. A1h 1R8-E1V voltage is not more than 1.53V when the computer is powered on. A2h 1R8-E1V voltage is not more than 1.53V when the computer is booting up. A3h 1R8-E1V voltage is not less than 1.53V when the computer is powered off. A4h 1R8-E1V voltage is not more than 1.53V when the computer is suspended. B0h 2R5-B2V voltage is more than 3.00V when the computer is powered on or off. B1h 2R5-B2V voltage is not more than 2.125V when the computer is powered on. B2h 2R5-B2V voltage is not more than 2.125V when the computer is booting up. B3h 2R5-B2V voltage is not less than 2.125V when the computer is powered off. B4h 2R5-B2V voltage is not more than 2.125V when the computer is suspended. C0h 1R25-E1V voltage is more than 1.50V when the computer is powered on or off. C1h 1R25-E1V voltage is not more than 1.063V when the computer is powered on. C2h 1R25-E1V voltage is not more than 1.063V when the computer is booting up. C3h 1R25-E1V voltage is not less than 1.063V when the computer is powered off. C4h 1R25-E1V voltage is not more than 1.063V when the computer is suspended. D0h 2R5-E1V voltage is more than 3.00V when the computer is powered on or off. D1h 2R5-E1V voltage is not more than 2.125V when the computer is powered on. D2h 2R5-E1V voltage is not more than 2.125V when the computer is booting up. D3h 2R5-E1V voltage is not less than 2.125V when the computer is powered off. D4h 2R5-E1V voltage is not more than 2.125V when the computer is suspended.
![](images/spacer.gif) |
