Текущее время: 31 окт 2026, 10:10
 Заголовок сообщения: Acer Aspire 7740G (JV70-cp) Starts immadietaly after AC connected, no POST.
СообщениеДобавлено: 12 ноя 2013, 01:19
Hello, I have problem with notebook Aspire 7740G JV70-cp. Laptop starts without pushing power switch (3,3V present on power switch), just after connecting ac adapter (laptop doesn't turn off when power switch pushing). The power consumption is 0,71A - no POST. Someone has been repairing before me, hm55 was reflowed. I have made a reball of hm55, I have reprogrammed bios from acer site, also ec kbc was reprogrammed. All voltages are fine, I substituted CPU, RAM - it is ok. RTC battery is OK. I think that problem is with bios dump, I need dump with Clean Me Region, but I have not enough posts to download. Thank you.
 Заголовок сообщения: Re: Acer Aspire 7740G (JV70-cp) Starts immadietaly after AC connected, no POST.
СообщениеДобавлено: 12 ноя 2013, 10:29
Светлая память
Светлая память
You don't needed BIOS with clear ME rigth now.
Any dump BIOS from this platform is applicable.
Try to replace hm55 - not reball.
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 21 ноя 2013, 03:21
Hello, I have changed HM55, but without any positive results. I have looked closely on voltages and there is no correct power supply to CPU. The resistance without CPU was 135[omega][/omega] - a bit low for sure, I desoldered ISL62883 and the resistance raised to 2,96M[[omega][/omega]. I will change the ISL and I will inform about results. Regards.
В этой теме нет новых непрочитанных сообщений. acer aspire 7740G (jv70-cp mb 09293-1) Есть подсветка-нет изображения
drumatizacia
27 мар 2019, 09:04
В этой теме нет новых непрочитанных сообщений. Acer 7740G (JV70-cp mb 09293-1) Нет изображения
Dipsi2505
11 июн 2021, 08:22
В этой теме нет новых непрочитанных сообщений. Toshiba C50-b-149 (la-b301p) Starts and shuts down after 6 seconds Need BIOS DUMP
в форуме Toshiba
draganzile
13 фев 2018, 02:52
В этой теме нет новых непрочитанных сообщений. Dell Vostro 3500 (Wistron DW50 Winery15) Starts by itself when put on charger, restarts after aprox. 10 second
в форуме Dell
gligurski
20 сен 2018, 17:25
gligurski Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba Satellite C660-M202 (la6842p rev:1.0) Notebook starts but does not display on the screen after 8-10 se
в форуме Toshiba
Ceyhun66
09 окт 2018, 06:17
pyry Перейти к последнему сообщению
Сейчас этот форум просматривают: kedrikov и гости: 152
