Dejmos писал(а):
Check sata connector (on this model some masters frequently break the connector), check sata quartz and sata line.
If one of the small capacitors (4 on one sata line) are broken you will get what you got.
Connector and 4 capacitors changed by working one but issue still. so where is SATA quartz? If you mean SATA frequency, I must say I checked it before, It was produced from Clock generator truly.(~100MHZ, checked by oscilloscope)
