Текущее время: 21 сен 2024, 09:47
 Заголовок сообщения: inspiron 4110 (Quanta V02A/R01A) no display
СообщениеДобавлено: 01 янв 2014, 19:34
hi guys
happy new year
there is a board that southbridg of it was so hot when connect the power
i change the southbridge
but now in turned on,but no display
it use 0.7 amper
i program the bios&EC
whats your view؟
 Заголовок сообщения: Re: inspiron 4110 (Quanta V02A/R01A) no display
СообщениеДобавлено: 02 янв 2014, 20:50
i think there is again southbridge problem. might be southbridge is not placed right. you have to replace or reball it.
СообщениеДобавлено: 13 янв 2014, 13:37
southbridge replaced
Not make a difference
СообщениеДобавлено: 14 янв 2014, 04:10
How much amps take when u plug jack in, and how much when power on?
СообщениеДобавлено: 14 янв 2014, 08:51
Check the PCH start sequence, if you find the Plataform reset signal (PLTRST#)is highly possible that the PCH works fine, if not, check the PCH start sequence backwards to try to find the problem.
All the power supplies are ok ? The system clocks are ok ?
Good Luck :men:
СообщениеДобавлено: 25 янв 2014, 13:26
how i should check this signals?
i dont have oscilloscope
whenturn it on PLTRST#=3.3V
СообщениеДобавлено: 06 фев 2014, 20:42
Check in power on sequence witch one signal is not present,
If u don't have osciloscope check voltages on quartzs, better than nothing.
What about voltages on coils? all ok?
СообщениеДобавлено: 11 фев 2014, 13:36
Topicstarter, an oscilloscope is highly recommended in such cases, try to find it. Are you sure your CPU is good? These CPUs are known for their frequent fails. Also install 100% working RAM module. Can you tell us pre-failure conditions of your laptop?
I'm advicing you to see is there any activity on BIOS flash pin 2 and LPC LAD0. Does BIOS you've flashed contains ME region? However, are there any hot chips? EC, LAN...
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Vostro 3450 (Quanta V02A (DAV02AMB8F1)) нет инициализации, переделка в UMA
в форуме Dell
Ghost_vlz
28 окт 2017, 13:14
Ghost_vlz Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP DV7- (DV7-4110) Помогите опознать детали
Дуся1
10 ноя 2022, 21:01
Дуся1 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Помогите опознать TSOT23-6 DC-DC U3 BCBCD стоит в Satcom 4110 HD
Rostyk.07
15 сен 2024, 00:25
felix2604 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell 3521 (Display problem help me) Display problem
в форуме Dell
ahmeterengul
12 июн 2017, 11:22
ahmeterengul Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron N7110 (Dell Inspiron N7110) Dell Inspiron N7110 BIOS
в форуме Dell
Dowlpack
24 фев 2015, 10:32
Dowlpack Перейти к последнему сообщению
Сейчас этот форум просматривают: Eool и гости: 30
