Текущее время: 08 июл 2024, 11:10
 Заголовок сообщения: HP 625 (Valima UMA) No power
СообщениеДобавлено: 28 янв 2014, 11:00
There is Hp 625 Valima. No Clock on Bios Pins(6th pin, 2th pin, 5th pin). so I track 6th from Schematic and saw it connected to IO(SMSC KBC1098). So I changed It by new one, But no changes, We have 3.3 on PWRSW and goes down when press it. Check PWRSW on SMSC so it is OK as switch. What can I do? Why SMSC not produces the KBC_SPI_CLOCK?
Don't give up without the fight.
 Заголовок сообщения: Re: HP 625 (Valima UMA) No power
СообщениеДобавлено: 28 янв 2014, 11:33
Заблокирован
№1 - check power to vcc1, vcc2
№2 - check clock to 70-71 pins ( 32768 Hz)
№3 - flash bios...
СообщениеДобавлено: 28 янв 2014, 12:06
№3 - flash bios...
VCC1 exist 3.3 V on all pins, VCC2 expect to produced after power on,
So frequency on 70-71th pin is True(checked by oscilloscope).
But no frequency on KBC_SPI_CLK.
СообщениеДобавлено: 28 янв 2014, 12:19
Заблокирован
remove SPI FLASH & check to 6, 5 , 2 pins
---------- Добавлено спустя 7 минут 13 секунд: ----------
look to http://www.vlab.su/viewtopic.php?p=62203#p62203
СообщениеДобавлено: 28 янв 2014, 12:44
Bios IC picked Up, so something changed(Amber LED blinking), I realized that BIOS must be read on start up. SO By focusing on Plug in time, CLK and SI, SO frequency observed, I it is interesting, Just on plug in time clock produced and SPI Flash read from KBC. But no power again. BIOS id true, KBC changed, SB changed, no reaction to PWRSW.
СообщениеДобавлено: 28 янв 2014, 20:26
OH, Clock was produced just a moment when you plug in!! in that time( less than a second) data read from bios. by changing U516(tps51117) now power on but no display!! now we have no LPC activity, IO & SB is true but no LPC.
В этой теме нет новых непрочитанных сообщений. HP 625 (Valima 2010 AMD C2 UMA) висит на пост-коде 43
2N3904
27 янв 2017, 12:02
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 625 (valima uma 2010) Не включается Wi-Fi
Artes86
11 окт 2018, 21:11
Artes86 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 625 (Valima) не включается
Филорентий
3423
13 фев 2015, 14:34
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 625 (inventec valima 2010) Не видит зарядку и не стартует после замены севера
cloze
18 июл 2015, 23:30
cloze Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 625 (Inventec Valima) post C5h
Черномор
18 авг 2015, 18:55
Сейчас этот форум просматривают: andrushka-tomilov@ya.ru, eugkov, ruzalit, saloedoff34 и гости: 20
