Текущее время: 28 май 2024, 21:06
 Заголовок сообщения: MSI OEM MS16811 V1.1 (Intel HM55) No start
СообщениеДобавлено: 07 апр 2014, 09:00
Hello,
I am from Uruguay (South America). Have a problem with a MSI notebook.
Power up ok, fan starts, power led turn on, but no video on lcd /hdmi/vga.
Changed ram and cpu for good tested ones, no luck.
GPU warms up normally, cpu remain cold.
Any help to check voltages or startup logic levels ?
Thanks in advance.
Leandro.-
 Заголовок сообщения: Re: MSI OEM MS16811 V1.1 (Intel HM55) No start
СообщениеДобавлено: 07 апр 2014, 11:36
Leonardo welcome!
Just look at the power BIOS?
Perhaps you need to flash the BIOS ... It may well be that he flew.
Alexey
lpraderi писал(а):
Hello,
Thanks in advance.
Leandro.-
СообщениеДобавлено: 07 апр 2014, 21:15
Thanks Alexey,
I will try to find a binary image of my bios somewhere.
SPI flash of my board: Winbond 25Q32BVSIG, f
First time for me that bios chip could flew,
this problem was suddenly , I did not flash a new bios .
Laptop is in his original state 2 year without a problem.
Maybe some virus corrupted bios,
will read flash chip on external programmer and let you know.
Leandro.-
СообщениеДобавлено: 08 апр 2014, 06:03
Update: also found a serial eeprom MX 25L512 (U5) this need to be read ?
СообщениеДобавлено: 08 май 2014, 07:58
After some investigation (and reading on forum) found that Macronix MX25L512 contents LPC EC firmware.
Found a working MS-16811 V1.1 motherboard donor to make working dumps of BIOS and EC.
Will update soon.
Posted after 1 hour 35 minutes 53 seconds:
U5 EC Firmware SPI Flash (512Kbits/64KB)
Posted after 26 minutes 47 seconds:
Dumped & checked both EC images (working/no-working) both have exact same content (md5 check).
1681EP21 Ver4.13
09/26/2011 17:54
Will do the same with BIOS chips.
В этой теме нет новых непрочитанных сообщений. Продам процессор Intel Core i3-2370M Mobile, OEM, new
thunder1976
20 июл 2014, 18:21
thunder1976 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus K52JC (HM55, Intel core I5/GF310) Был залит. Отгнило пару резистовов
Alex_F
06 апр 2016, 22:12
Alex_F Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. OEM Windows - правовые вопросы
Бим
14
5936
24 июн 2015, 21:23
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus 553MA free dos + OEM лицензия
peit
2505
24 сен 2016, 06:09
dark7light1 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. mb40ii5 (neo (clevo oem)) turns off about 5 minutes on battery
в форуме Clevo
adonis827
03 май 2016, 18:20
adonis827 Перейти к последнему сообщению
