Текущее время: 01 июн 2024, 11:04
 Заголовок сообщения: Кто-нибудь знает, как изменить регион HP Photosmart C4200?
СообщениеДобавлено: 10 мар 2011, 19:57
Меня не reset нужен, я ета я знаю, если ктото интересует :
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printers (products with keypads only). Resetting your printer will reset your printer to its original state.
Resets for all HP all-in-one printers with keypads:
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
For Box-type models (No Keypads):
1. Unplug the power cord from the printer.
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
Reset HP Photosmart C4200 series, C4300 series and C4400 series Procedure:
HP Photosmart C4200 Series Includes:
HP Photosmart C4205
HP Photosmart C4210
HP Photosmart C4240
HP Photosmart C4250
HP Photosmart C4270
HP Photosmart C4272
HP Photosmart C4273
HP Photosmart C4275
HP Photosmart C4280
HP Photosmart C4283
HP Photosmart C4285
HP Photosmart C4380 Series Includes:
HP Photosmart C4380
HP Photosmart C4383
HP Photosmart C4385
HP Photosmart C4400 Series Includes:
HP Photosmart C4435
HP Photosmart C4440
HP Photosmart C4450
HP Photosmart C4472
HP Photosmart C4473
HP Photosmart C4480
HP Photosmart C4483
HP Photosmart C4485
HP Reset Printer Steps:
1. Press Cancel and Power, at the same time.
2. Then, the Unit will ask for a Key Combo, press blue, green, gray buttons (in order) for this.
3. “Support Menu” should appear.
4. Go to Resets menu and use the semi-full reset.
Support Menu
(Blue for Up, Gray for Down and Green for OK)
* Firmware Revision (hint:push gray button to move to the next menu item)
* Scan Diagnostics Menu
* Reports Menu
* Print Tests Menu
* System Configuration Menu
* Resets Menu
* Information Menu
Alternate HP reset procedure (for older products):
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
Reset for the Photosmart C5100 Series:
* HP Photosmart C5140 All-in-One Printer
* HP Photosmart C5150 All-in-One Printer
* HP Photosmart C5175 All-in-One Printer
* HP Photosmart C5180 All-in-One Printer
* HP Photosmart C5183 All-in-One Printer
* HP Photosmart C5188 All-in-One Printer
* HP Photosmart C5190 All-in-One Printer
1. Unplug the power cable from printer while the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
3. Just turn on the printer and configure your printer new
Клиент покупил принтере из Дубая и поставка не соответствует с локальная.
 Заголовок сообщения: Re: Кто-нибудь знает, как изменить регион HP Photosmart C42
СообщениеДобавлено: 11 мар 2011, 14:17
Все очень просто.
Надо иметь принтер под рукой. Включенный. Записать на бумажку код продукта и серийный номер.
Потом позвонить в Москву, в HP (есть бесплатный тел. 8-800-....) и описать проблему.
Далее они будут говорить, что нажимать, спрашивать что пишет, и сгенерируют код, который надо ввести.
После этого станет Европейским.
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 17 мар 2011, 23:41
В обшем процедура такая:
Надо напечатать диагностическую страницу из драйвера и ничего другое.
Потом из программа инструментом задерживая кнопка "Ctrl" два клика на картинке HP в низ слево.
Открывается окна с пят побласти для введения кода для замена региона.
Полсе етога если региональны представител нехочет сделать ( как у меня, потому что они должны сделот безплатно ) связываетес с поддержка HP Live Chat на щатском сервере. Диктуете им что из диагнастичная страница они хотят, они дают код для смена региона безплатно.
Регион поставки можна менят 3 раза, 50 попъытки введения кода.
В этой теме нет новых непрочитанных сообщений. Honor 7c. как изменить страну(регион)
в форуме Huawei
aletdin
25 янв 2023, 22:52
Facile Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Замятие бумаги.HP Photosmart C4283
[ На страницу: 1, 2 ]
Compute
48
17304
18 янв 2019, 19:31
Алексей Новой Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Ищу дамп EEPROM 24c64 hp photosmart c3183 для 132,135 картриджа
korochinskiy
22 окт 2019, 17:42
korochinskiy Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Принтер, hp photosmart c3183,выдает ошибку Е,мигает индикатор черного картриджа.
lomess
18 май 2020, 00:02
lomess Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP Photosmart 7450 может ли работать без цветного картриджа
lomess
1320
29 июн 2023, 20:01
