Текущее время: 16 июн 2024, 03:53
kandyan
Заголовок сообщения: Re: Acer Aspire 5755 (P5WE0 - LA-6901P) No display ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 15 май 2014, 14:54 |
Зарегистрирован: 04 апр 2014, 20:52 Наличности на руках: 15.09 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 70 Откуда: Sri Lanka
stafford писал(а): exchange isl 95831. Good idea but replacing ISL95831 is the last thing I expected to do. Before that I need to know why +CPU_CORE is available and +VGFX_COREP not available.
Заголовок сообщения: Re: Acer Aspire 5755 (P5WE0 - LA-6901P) No display ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 15 май 2014, 14:58 |
+VGFX_COREP will be only afer some post codes.
kandyan
Заголовок сообщения: Re: Acer Aspire 5755 (P5WE0 - LA-6901P) No display ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 15 май 2014, 15:08 |
MSF113 писал(а): +VGFX_COREP will be only afer some post codes. I cannot understand what you are saying.Sorry if I am mistaken. stafford писал(а): I had a similar situation. i replace isl and kbc. if isl - bad, to usualy +VGFX_COREP bad. I dont have ISL now. I will change ISL and let you know the result. But if anyone had this problem please advice me.
Заголовок сообщения: Re: Acer Aspire 5755 (P5WE0 - LA-6901P) No display ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 15 май 2014, 15:19 |
First, system power on, all voltages up, except +VGFX_COREP Second, system start, you must have some POST's, only after this +VGFX_COREP up too.
kandyan
Заголовок сообщения: Re: Acer Aspire 5755 (P5WE0 - LA-6901P) No display ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 15 май 2014, 15:28 |
MSF113 писал(а): First, system power on, all voltages up, except +VGFX_COREP Second, system start, you must have some POST's, only after this +VGFX_COREP up too. Ok. I got it now. There is no POST screen or anything. Just start the laptop but no display. So in this case what are you suggesting to do. Because I thought +VGFX_COREP is the problem. If you are correct now i think KB might be bad for some reasons. What do you think? Where to start find this problem?
Заголовок сообщения: Re: Acer Aspire 5755 (P5WE0 - LA-6901P) No display ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 15 май 2014, 15:45 |
Check LAD0...LAD3 via oscolliscope, PLT_RTS# must be high, check what Flash ROM's is reading
kandyan
Заголовок сообщения: Re: Acer Aspire 5755 (P5WE0 - LA-6901P) No display ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 15 май 2014, 16:10 |
MSF113 писал(а): Check LAD0...LAD3 via oscolliscope, PLT_RTS# must be high, check what Flash ROM's is reading My oscilloscope has broken.So i ordered new one but it still haven't received.I will post the results when it got here.thanks
Заголовок сообщения: Re: Acer Aspire 5755 (P5WE0 - LA-6901P) No display ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 22 авг 2014, 11:31 |
Check LAD0 signal. What do you see?
