Текущее время: 28 сен 2024, 12:24
Chazy-Chaz
Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) No input voltage Добавлено: 30 май 2014, 23:23 |
Зарегистрирован: 18 янв 2012, 19:14 Наличности на руках: 442.17
Сообщения: 656 Откуда: Каменец-Подольский, Украина
I'd try to replace PU4, because KB doesn't take part in this block of scheme. B+ should be even without KB. kandyan писал(а): Thereafter everythings ok - What is OK? You have no voltage on input. If you say, that was lost after replacing KB, than what stops from getting old KB back?
siberian
Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) No input voltage Добавлено: 31 май 2014, 10:43 |
Сообщения: 10113 Откуда: Тюмень
kandyan писал(а): So I replaced the KB with KB9012QF New KB9012QF without EC FirmWare kandyan писал(а): After that I have change KB with KB930QF as schematic said KB9012QF=KB930QF. KB930QF and KB9012QF not interchangeable, since KB930QF has an external firmware while the firmware inside KB9012QF
kandyan
Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) No input voltage Добавлено: 02 июн 2014, 08:16 |
Зарегистрирован: 04 апр 2014, 20:52 Наличности на руках: 15.09
Сообщения: 70 Откуда: Sri Lanka
Chazy-Chaz писал(а): I'd try to replace PU4, because KB doesn't take part in this block of scheme. B+ should be even without KB. kandyan писал(а): Thereafter everythings ok - What is OK? You have no voltage on input. If you say, that was lost after replacing KB, than what stops from getting old KB back? I said "everythings ok" meant after replacing KB there were no blinking LEDs :D Are you sure B+ should be there even without KB? Also after i went through KB9012QF, i figured out KB930QF and KB 9012QF are not interchangeable. I dont have spare KB9012QF right now. So I'll have to wait for few days. siberian писал(а): kandyan писал(а): So I replaced the KB with KB9012QF New KB9012QF without EC FirmWare kandyan писал(а): After that I have change KB with KB930QF as schematic said KB9012QF=KB930QF. KB930QF and KB9012QF not interchangeable, since KB930QF has an external firmware while the firmware inside KB9012QF Yes "siberian". I figured after went through the KB9012QF datasheet they are not interchangeable. Cz KB9012QF has 128K embedded flash. Do we need to do something with that after replacing KB9012QF? I mean reprogramming the firmware?
RsM
Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) No input voltage Добавлено: 02 июн 2014, 11:45 |
Модератор |
Зарегистрирован: 12 окт 2012, 21:53 Наличности на руках: 5,136.84
Сообщения: 8377 Откуда: Сыктывкар
kandyan писал(а): Do we need to do something with that after replacing KB9012QF? I mean reprogramming the firmware? yes, you need programm it. And you'll be need a special programmer, which support it EC. like viewtopic.php?f=170&t=16421 or SPI TT ( http://ejtag.ru/shop.php?cat=1#4 )
kandyan
Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) No input voltage Добавлено: 05 июн 2014, 19:51 |
RsM писал(а): kandyan писал(а): Do we need to do something with that after replacing KB9012QF? I mean reprogramming the firmware? yes, you need programm it. And you'll be need a special programmer, which support it EC. like viewtopic.php?f=170&t=16421 or SPI TT ( http://ejtag.ru/shop.php?cat=1#4 ) Thanks for the advice. But in this laptop there are two IC s for Main BIOS and EC (U36 and U42). Therefore do we need to reprogram "128K embedded flash" on KB9012QF? I means with that there 3 firmwares. or we need to re program only U36 and U42? I have seen some are selling programmed KB9012QF for aspire V3, E1, Samsung and Lenovo models. I am really confused here Cz usually we only re program main BIOS and EC. P.S. I cannot buy anywhere else other than ebay. Cz they ship items for my country. If you can plz let me know some links in ebay cz i didnt find it (kb9012 programmer) there.
siberian
Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) No input voltage Добавлено: 05 июн 2014, 20:16 |
kandyan писал(а): But in this laptop there are two IC s for Main BIOS and EC (U36 and U42) No, it's ME + BIOS
kandyan
Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) No input voltage Добавлено: 05 июн 2014, 23:17 |
siberian писал(а): kandyan писал(а): But in this laptop there are two IC s for Main BIOS and EC (U36 and U42) No, it's ME + BIOS Are you saying U36 and U42 is for ME+BIOS.....? Could you plz explain about this ME furthermore..? Is it means Management Engine something? I really don't know what is it. After you said that I understand there are 3 progrmmable chips in Acer Aspire V3-571 MB U36, U42 and KB9012QF..... What are the chip do i have to reprogram then? I mean which one is Main BIOS and which one is EC?
kandyan
Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) No input voltage Добавлено: 08 июн 2014, 18:45 |
RsM писал(а): 4MB - MAIN BIOS 2MB - Managment Engine fw (intel part) 128kB in KB9012 insyde - EC fw
if you change 9012, you will need to program EC fw into it. 128kB Thanks for the explanation. I have SOFI SP8-A USB programmer and shall I program kb9012 by using it? also i need to know whether firmware programming is perform when kb9012 on the motherboard or off the motherboard? Basically I want to know how to program KB9012.
