Текущее время: 29 июн 2024, 00:20
 Заголовок сообщения: monitor / lcd tv LG M227WD led flashing on the power button
СообщениеДобавлено: 19 авг 2014, 18:01
the source code of the card: PLLM-M702A.
The monitor arrived functioning normally always presenting the message of proper resolution in 1920 by 1200. After a few minutes running, the image disappears and the led on the power button flashes.
The message of proper resolution 1920 by 1200 always appears independent of the resolution I choose. It seems that triggers the protection circuit of the circuit. It may also be the voltage that feeds the bulbs are above normal that triggers the protection circuit.
The exciter of output high is used integrated AOP605 (two integrated)
Tried replacing the bulbs, but the problem continues.
 Заголовок сообщения: Re: monitor / lcd tv LG M227WD led flashing on the power button
СообщениеДобавлено: 19 авг 2014, 18:21
Заблокирован
Try to clear data EEPROM IC105 - AT24C512
record in the data buffer FF or 00
«Кто владеет информацией - тот владеет миром»
СообщениеДобавлено: 19 авг 2014, 20:40
you mean, clear the eeprom and then rewrite
СообщениеДобавлено: 19 авг 2014, 22:25
Заблокирован
put clean eeprom
 Заголовок сообщения: Re: monitor / lcd tv LG M227WD led flashing on the power button ( решена )
СообщениеДобавлено: 25 авг 2014, 20:41
I believe I have solved the fault with the monitor replacing the smd capacitor C306 which should be 10nF for another of equal value because after the exchange, the monitor was turned on for several hours without presenting the problem cited.
СообщениеДобавлено: 28 авг 2014, 15:48
unfortunately I will have to continue to examine this monitor, the problem remains
В этой теме нет новых непрочитанных сообщений. tv lcd lg32pc5rv no power , led board principal flashing
в форуме LCD
eletmoraes
19 дек 2017, 15:57
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. monitor benq monitor benqGL2450-B (шасси: 9H.LA9LB.DBB) power dead
в форуме BenQ
eletmoraes
24 дек 2021, 01:24
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Hp (4520s) Not power on ... dc jack led flashing
nasser_pczone1
18 июл 2018, 12:38
nasser_pczone1 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. hp elitebook 2540P (MB KATIO LA-5251P ) no power led flashing panel 2 times
eletmoraes
27 апр 2019, 04:46
