Текущее время: 26 июн 2024, 19:34
 Заголовок сообщения: HP G6 (DA0R13MB6E0 R13) Discharging  [РЕШЕНО]
СообщениеДобавлено: 05 апр 2014, 11:01
I have HP G6 laptop with small problem i guess. its working nicely without an issue but when it turns off, it cannot power up (turn on) again. However if battery taken out ant put it back again its working. So i think there is something with the discharging circuit or somewhere else which is not fully discharged.
Anyone had this kind of trouble?
 Заголовок сообщения: Re: HP G6 (DA0R13MB6E0 R13) Discharging
СообщениеДобавлено: 05 апр 2014, 11:21
first of all desirable to test with another battery and update BIOS
СообщениеДобавлено: 06 апр 2014, 08:18
There was some kind of a problem in PQ6 and PQ8. I guess they were not functioning properly. But when i checked them pinout readings were ok. however after i changed those components laptop get back to work as it was. Thanx for your kind support.
p.s. i replaced new RTC battery plus update to the latest bios after reassembled.
СообщениеДобавлено: 07 апр 2014, 08:02
Everythings going well except without battery same problem emerged. With battery everythings look fine. But customer said that this is enough for now. So i gave it back.
СообщениеДобавлено: 22 авг 2014, 11:24
Customer brought it back and asked me to give it a try and this time i replaced Super IO chip as well. Problem solved this time and I applied same solutions for few latest HP notebooks which were showing symptoms like sudden shut downs, only the 1st time laptops can be start. no power with blink codes. mainly there were in SIO and BIOS (EC+MAIN).
В этой теме нет новых непрочитанных сообщений. DA0R13MB6E0 REV: E R13 куплю
в форуме Куплю | Buy
servis37
2204
06 ноя 2016, 10:39
radeon6 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. hp g7-1152er (Quanta R13 Rev: E (DA0R13MB6E0)) прошивка мультиконтроллера
Сабиров
31 мар 2019, 13:26
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Pavilion g7-1301er (Quanta R13 - DA0R13MB6E0 REV: E) Нет инициализации, нет питания процессора
guljaysv
13
2752
13 фев 2020, 22:03
guljaysv Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. G6-1057ER (DA0R13MB6E0) Не видит АКБ
Saiberex
04 дек 2014, 13:05
reset-irk Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Ноут HP G6-1158er (da0r13mb6e0) не включается, нет реакции на кнопку
daki
13 мар 2015, 17:00
daki Перейти к последнему сообщению
Сейчас этот форум просматривают: Alex.77, balch, felix2604, Nurzone, Даврон и гости: 41
