Текущее время: 22 ноя 2024, 07:46
 Заголовок сообщения: E1-570 (LA-9535p) No reaction on power button
СообщениеДобавлено: 19 дек 2014, 17:38
Hello everyone. Laptop a little flooded in KBC area. KBC soldered new (programmed).
+3VALWP, +5ALWP, +VL, +3VLP, +3VAWLP_PCH, +5VALWP_PCH - present. S5 enabled, PCH is giving PM_SLP_S5#.
Power consumption 0,01A. After switch power button, nothing is happening. ON/OFF correctly getting to 0V when pressed.
My worries - PCH_RSMRST# - 0V, so PBTN_OUT# doesn't react and there is 3,3V always. BIOS reprogrammed. There is no communication between PCH <-> BIOS. No oscillograms.
Appreciate your help. Thanks.
 Заголовок сообщения: Re: E1-570 (LA-9535p) No reaction on power button
СообщениеДобавлено: 19 дек 2014, 19:32
Участник АСЦ
Участник АСЦ
Check lid_sw# is high
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 19 дек 2014, 21:02
LID_SW# 3,3V High. Reacting properly on magnes.
СообщениеДобавлено: 19 дек 2014, 21:04
Участник АСЦ
Участник АСЦ
Ec reset is high?
СообщениеДобавлено: 19 дек 2014, 22:04
EC RESET - 3,3V
СообщениеДобавлено: 19 дек 2014, 23:35
PCH need to replace
PCH do wymiany
兰克乌是松尔赫, 你操舰军斯罗俄
СообщениеДобавлено: 20 дек 2014, 00:05
Are you sure? I would like to change the Bridge as extremity. PCH_RSMRST# resistance 10k OHM.
СообщениеДобавлено: 20 дек 2014, 00:17
I think, that all you need is already verified :mi_ga_et:
兰克乌是松尔赫, 你操舰军斯罗俄
СообщениеДобавлено: 20 дек 2014, 01:05
No suspicion of KBC failure? 9012 receiving PM_SLP_S5# from PCH, but doing nothing RSMRST# 0V. On the other hand your theory is right because there is no communication HUB <-> BIOS. Please try to explain me why Power Led doesn't light?
СообщениеДобавлено: 20 дек 2014, 11:06
i have a motherboard that has the same situation, i might start working on it soon, thanks for the advice
СообщениеДобавлено: 31 дек 2014, 03:05
After rebuild a 3,3V trace, laptop turns on and shut down after few seconds. Stop at 0,78A, no POST. There is no +VGFX_CORE, but +CPU_CORE 1,1V. I changed the BIOS, but still the same. No voltages VCC_AXG_SENSE and VSS_AXG_SENSE. Any ideas?
СообщениеДобавлено: 02 янв 2015, 16:06
It seems that LPC BUS is working - 3,4V, PCI_CLK_LPC - 33MHz, but PLT_RST# - 0V. Any help?
 Заголовок сообщения: Re: E1-570 (LA-9535p) No reaction on power button  [РЕШЕНО]
СообщениеДобавлено: 26 фев 2015, 09:32
I had to rebuild some traces (power supply 3,3V for KBC). Then was problem with SYS_PWROK signal. It was shorted to GND. Changing the U1 solved the problem.
Thanks for advices.
В этой теме нет новых непрочитанных сообщений. N56vm (N56vm) Power button
alshfu
04 дек 2015, 14:27
FearCult Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS K200MA K200M SERIES I/O AUDIO USB PORT POWER BUTTON BOARD 60NB04U0-IO1020
в форуме Куплю | Buy
o_elshad
16 мар 2016, 19:28
o_elshad Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MacBook Pro 13 (A1278 820-3115-B) Power button long press to turn on
в форуме Apple
bridx
26 фев 2017, 02:26
andromedax Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. razer blade stealth i7-7500u - power button not reponse
в форуме temp
ngvuanh
21 мар 2018, 04:13
ngvuanh Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MacBookPro 15 Late 2013 (820-3787-A) Need to hold power button ~ 6 sec to start and slow
в форуме Apple
RalphFix
10 ноя 2018, 05:45
2wtn Перейти к последнему сообщению
Сейчас этот форум просматривают: kuzovoi и гости: 87
