Текущее время: 04 июн 2024, 15:08
NEME$I$
Заголовок сообщения: Re: freezes on the home screen from the manufacturer , keyboard does not work Добавлено: 08 апр 2015, 21:12 |
Зарегистрирован: 02 июл 2014, 20:44 Наличности на руках: 1,540.14
Сообщения: 1327 Откуда: Алтайский край
Try a known good power adapter. If disconnected from the Board all the periphery and inserted only the processor and memory,there is a voltage of 5V on the USB and PS2 but the fee remains hanging not responding to the keyboard,it is likely a faulty South bridge. You can try to change the Multicontroller,but I think it will not help,although in my practice there was a case hung from Multicontroller,not responding to the keyboard,as you have. Processor supported motherboard? Previously worked with him fee?
_________________ Стёрли.
