Текущее время: 21 ноя 2024, 21:09
 Заголовок сообщения: Next GT440 2GB artifacts after loading video driver
СообщениеДобавлено: 16 май 2015, 19:20
Hi guys. I have a GT440 that is working without problems as Standard VGA Adapter, no artifacts, no nothing. After installing official nVidia drivers and restarting, a couple of seconds after windows starts loading (splash screen-after loading vga driver) it shows artifacts as if GPU needs reball (blue lines) and driver stops working. To be honest I don't have clue what the problem might be. I will appreciate any info if anybody had a similar problem and has any info.
Thanks in advance.
 Заголовок сообщения: Re: Next GT440 2GB artifacts after loading video driver
СообщениеДобавлено: 16 май 2015, 22:23
Thanks in advance.
Tray to boot in fail-safe mode and see if you can select 800x600 resolution,(or 640x480) after that, boot normally and check if it works properly.
Probably, as you mention, GPU or memory chips need reball or are damaged.
СообщениеДобавлено: 17 май 2015, 18:39
Thanks for the reply. Booting into low resolution mode (640x480) has the same effect (horizontal blue lines). Booting into safe mode everything is ok. I can change resolution but again botting normally artifacts appear and driver stops. I have already reflowed GPU. but there are a total of 16 VRam Chips. a little bit lazy to reball em.
СообщениеДобавлено: 17 май 2015, 21:18
What about heating v-ram and gpu and watch changes?
Does it work properly while in bios setup when heating gpu?
СообщениеДобавлено: 04 окт 2015, 01:09
1-change power cap..
2-rework gpu
СообщениеДобавлено: 22 окт 2016, 22:12
Заблокирован
Nothing much you can do here, only try to heat up gpu(reflow) to see if that will help!
СообщениеДобавлено: 22 окт 2016, 22:17
Markos7, a you spamer?
В этой теме нет новых непрочитанных сообщений. Zotac RTX 2080ti artifacts after driver and 0 errors on MATS, No error 43, any ideas?
metobala
24 июл 2021, 07:20
Joe24 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. inno3D gt440 2gb ddr3 Нет питания GPU и памяти.
Dmt
03 янв 2021, 05:36
quasar100 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Zotac GTx 980ti articstorm - artifacts after drive installation
TheMArcos
13
2427
27 мар 2020, 06:40
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Nextstar Next Ye-18500 Hd
в форуме GPS и спутниковое оборудование | Satellite equipment
apollo
02 фев 2021, 23:17
eprom10 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Поведение плат до обновления UEFI под next gen CPU
Leeroy
1443
19 дек 2022, 15:35
Leeroy Перейти к последнему сообщению
Сейчас этот форум просматривают: madking и гости: 64
