Текущее время: 17 июн 2024, 00:28
abuholm
Заголовок сообщения: Re: Mscbook A1278 (820-3115B) Battery not recognized ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 11 мар 2015, 14:27 |
Зарегистрирован: 17 мар 2013, 15:22 Наличности на руках: 28.00 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 199 Откуда: Ghana
arjuk писал(а): in first try remove d6950 Yes I have done that already and the voltages are still the same..
abuholm
Заголовок сообщения: Re: Mscbook A1278 (820-3115B) Battery not recognized ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 18 мар 2015, 00:01 |
Mechanical писал(а): Try to change ISL6529. I have changed ISL6259 and the voltage is now 3.4v for both signals but the battery is still not recognized. I'm thinking that it might be a firmware issue or faulty SMC chip. Posted after 7 minutes 39 seconds:gs84 писал(а): measure voltages on all pins of Q7050 Pins 1-3 has 12.3v and pin 4 also 12.3v whereas pins 5-8 has 0v with empty battery connected.
abuholm
Заголовок сообщения: Re: Mscbook A1278 (820-3115B) Battery not recognized ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 18 мар 2015, 11:20 |
gs84 писал(а): What about adapter jack LED (with and without the battery)? Try to find and replace on another battery. Adapter LED is green with and without battery. The macbook works on a charged battery even though battery is still not recognized and the macbook's battery charges in another macbook.
abuholm
Заголовок сообщения: Re: Mscbook A1278 (820-3115B) Battery not recognized ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 29 мар 2015, 18:16 |
Mechanical писал(а): Might be SMC faulty. Try to update firmware. I have correct firmware but macbook says "this software is not supported on your system".
abuholm
Заголовок сообщения: Re: Mscbook A1278 (820-3115B) Battery not recognized ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 11 май 2015, 21:57 |
clawhammer писал(а): You should find the reason of SMBUS_BATT_SDA drop out = 2.3v Resistance must be between 10-13kOhm form SDA, SCL to GND, and voltage 3.4 both.
Check R5280, R5281 resistance in switched off state - it must be 2.0 kOhm both. R5281 was high and after replacing, both SDA and SCL voltage is 3.4v but battery is still not recognised.
