bridx писал(а):
igils писал(а):
Пробуйте.
Thank you. I will try it tomorrow and let you know how it behaves.
Hello,
I did try your dump. Now the keyboard backlight turns on when the machine is switched on which is a good sign. On further checking the processor and PCH are damaged due to the heat air by the previous guy who had checked it. Thank you so much for your help. I will now order a new board for the client.
