Текущее время: 21 сен 2024, 04:51
 Заголовок сообщения: Asus K55DR (AMD) no power
СообщениеДобавлено: 10 авг 2015, 16:27
Hi everyone,
i'm from Italy, and i'm new here.
I'll try to explain my problem as best as i can.
A friend gave me an asus K55DR (motherboard model K55DE rev 2.0) with black screen and fan at max speed.
As soon as he gave me the laptop, i tried it, it started up correctly (fan at max speed) but after a min the screen become black, then it remains black forever.
Tried to replace thermal paste, now fans goes at normal speed, but screen remains black.
Tried to reflash bios with some dumps found on internet, issue remains, so i tried to replace FCH two times.
Now the laptop doesn't power on at all, no fan, front led of power light up for 1 sec, then nothing (if you want to see it lighting up again, you have to disconnect and reconnect power plug or battery).
Power button doesn't work with AC adapter (as soon as i connect power plug, power led light up for 1 sec then nothing), but works with battery (as soon as i connect battery, no led light up, but when i push power button, power led blows for 1 sec then nothing).
Tried to put back original FCH, same issue remains. Tried to reflow CPU socket and replace GPU, same issue remains.
Can't find any short on the motherboard, no heat.
Some voltages are present, such as Vbattery (10.65V) and Vacadapter (19V), vbios, 5V etc....
Just noticed a strange thing...if i measure resistance across capacitors on top of FCH, only 3 caps are in short, the others are good.
If i desolder FCH the caps on top are not shorted anymore, so something is short on the motherboard (i suppose those 3 caps shouldn't be in short).
Please help guys :ny_tik:
 Заголовок сообщения: Re: Asus K55DR (AMD) no power
СообщениеДобавлено: 18 авг 2015, 18:49
i think you should find another dump and reprogram bios . are you sure you got a correct dump ?
СообщениеДобавлено: 22 авг 2015, 14:49
i don't know mate...tried to download 3 different dump, every dump gives me the same issue.
Could you supply me a correct dump for K55DR (motherboard model K55DE rev 2.0) or a schematic?
thanks
СообщениеДобавлено: 04 сен 2015, 15:29
please help
СообщениеДобавлено: 04 сен 2015, 23:48
which resistance? give a picture of that caps.
兰克乌是松尔赫, 你操舰军斯罗俄
СообщениеДобавлено: 05 сен 2015, 01:48
here you are friend!
Even without CPU and RAM installed, same issue remains.
When i push power button, front power led remains green.
But no heat, no fan spinning...like dead.
Changed FCH 3 times...is not FCH.
If i desolder FCH those 3 caps are not anymore in short...they are in short only when FCH is soldered to the mobo.
But i don't know if they should be in short...i suppose not.
Please help, thanks
СообщениеДобавлено: 10 сен 2015, 23:11
tried to replace CPU but same issue remains
EDIT: found out the power on sequence of K55 and verified it point by point, i got voltage from 0 to 11, 12=0V
Here you are: VBAT, +3VA_EC, EC_RST#, VSUS_ON, SUS_PWRGD, PM_RSMRST#, PWR_SW#, PM_PWRBTN#, PM_SUSC#, SUSC_EC#, PM_SUSB# are all 3.27V or 3.35V.
then the 12nd point is SUSB_EC# and is 0V. tried to force it at 3.3V but nothing changed.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus K55DR (Asus K55DR) Странное поведение шим дежурки
Edn
18 дек 2017, 14:38
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS K55DR (K55DR) Нет картинки
NoNick88
12
3122
28 окт 2019, 10:46
lmax220588 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. K55DR (K55DE (K55DR)) Нет инициализации.
maxlabt
12
2479
03 июн 2020, 01:01
maxlabt Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus k55dr (asus k55de) опознать мосфет
romaya
24 сен 2015, 23:18
remax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS K55DR (asus k55de rev2.0) помогите опознать элементы
Dimasik
17 апр 2017, 11:10
Dimasik Перейти к последнему сообщению
Сейчас этот форум просматривают: Yandex [BOT] и гости: 48
