Hits писал(а):
This service is necessary for those who for some reason - lost the original contents of the EFI firmware chip (for example, as a result of incorrect password removal UEFI), the same way if you placement PCH on your board(Intel 82hm76/77/87 etс).
It's fix troubleshoot - in ASD "XXX firmware corrupt", slow loading OS, hangs at OS boot time, slow work in the operating system ( stroboscopic effect when page swipe in the OS), the correct EFI unlock.
I got a liquid damaged 820-3209-A board with management engine missing... plus some temp sensors failing.
I bought the laptop this way and to my knowledge no password removal had been done.
How can I find out if my firmware is really corrupt?
Can you see this if I send you the original bin file?
