Заголовок сообщения: HP 242 G1 (6050A2545601-MB-A02) NOT SWITCHING ON
Добавлено: 12 сен 2015, 17:58
Зарегистрирован: 29 ноя 2012, 22:23 Наличности на руках: 0.01 Сообщения: 172 Откуда: Kenya
Hi,
Could anyone have a working dump?
Regards.
Заголовок сообщения: Re: HP 242 G1 (6050A2545601-MB-A02) NOT SWITCHING ON
bridx
Добавлено: 12 сен 2015, 20:17
igils писал(а):
Official site + your DMI.
Thank you. I have put your code, now when i press the power button the fan moves a bit. I think the Embedded Controller code is the issue. Could you have one I can try ?
Добавлено: 29 сен 2015, 07:30
I have ordered another board, I will provide a working dump when it arrives.
bridx
Добавлено: 28 окт 2015, 14:12
Hello,
The working board did arrive and tested fine. The only difference is the old board supported 2nd generation processors the new one supports 3rd generation. The EC code was in Pm25LD512 which my programmer cannot read its chip ID, So i did a few dumps from different chip companies with the some size 25*512. Hope it helps.
Regards.
Сейчас этот форум просматривают: vamark7 и гости: 46
