Текущее время: 21 ноя 2024, 18:23
 Заголовок сообщения: X230 Won't turn on (X230 Won't turn on) X230 Won't turn on
СообщениеДобавлено: 23 сен 2015, 01:03
I got this laptop Lenovo X230 but there is no sign of life it won't turn on and there also no lights burning.
Whats the first step to look for a Fuse maybe?
can somebody help me please :bra_vo:
 Заголовок сообщения: Re: X230 Won't turn on (X230 Won't turn on) X230 Won't turn on
СообщениеДобавлено: 25 сен 2015, 01:37
hi, nay my friend fuse isn't first thing you have to do, first you have disconnect battery, second reset bios, third disconnect all hardwares, then after that try understand what is happen in real... Go ahead!
одна голова хорошо- а две мутант
СообщениеДобавлено: 25 сен 2015, 01:42
Ok,
so i must reflash bios chip with a new file?
Posted after 25 minutes 53 seconds:
How to open this file??
Wistron dasher-2 BDV file
СообщениеДобавлено: 25 сен 2015, 06:14
viewtopic.php?f=58&t=6140&start=40 (ctrl+f "x230") then you'll see in that page link for download (Lenovo ThinkPad X230 Wistron LDB-2 Bios dump SPI1(8MB) + SPI2(4MB)) download it and you need use programmer, i think when you will read bios file you'll understand which you need update ;) (i never did't update this laptop bios but i think socond (spi2) one is multiprocessor bios file so you need update (psi-1))
СообщениеДобавлено: 25 сен 2015, 16:46
Arrester писал(а):
http://vlab.su/viewtopic.php?f=58&t=6140&start=40 (ctrl+f "x230") then you'll see in that page link for download (Lenovo ThinkPad X230 Wistron LDB-2 Bios dump SPI1(8MB) + SPI2(4MB)) download it and you need use programmer, i think when you will read bios file you'll understand which you need update ;) (i never did't update this laptop bios but i think socond (spi2) one is multiprocessor bios file so you need update (psi-1))
I've programmed both bios chips but no luck, still no lights or any sign of life
СообщениеДобавлено: 26 сен 2015, 06:25
Try check the all Standby power controllers, may be some controller is heating? problem is can be everywhere, start check from power jack till 5.5v controller (it is weakness of lenovo) and charge controller, i think problem is can be there, take the tester and check for short circuit too....
В этой теме нет новых непрочитанных сообщений. Dell Optiplex 745 won't turn on
в форуме Dell
mohkam3000
29 авг 2015, 10:39
usmankhan Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Latitude D830 (DAJM7BMB8F0 ) Laptop won't turn on if BIOS battery exist
в форуме Dell
cygron
02 мар 2020, 05:47
cygron Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Portege A30-C-13E (FSEPSY2) Laptop won't turn on after update
в форуме Toshiba
nikovmiroslav
22 июл 2021, 21:28
nikovmiroslav Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Poco M3 won't turn on or charge
в форуме Xiaomi
borisz94
3992
25 янв 2024, 21:36
adulterer Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS X555LD turn on with abnormal fan spin and turn off
kandyan
04 мар 2022, 09:55
kandyan Перейти к последнему сообщению
Сейчас этот форум просматривают: agsojer, burda11b, DHA3196, dizel2169854, Google [Bot], GrassPlus, phoma, Scholes121 и гости: 69
