Текущее время: 22 ноя 2024, 00:04
 Заголовок сообщения: Is there an alternative to install windows 7 or later on an LG Netbook with no DVD player?
СообщениеДобавлено: 05 окт 2015, 01:37
Accessory that I have at the moment would be a pendriver 2GB and USB notebook hd case
 Заголовок сообщения: Re: Is there an alternative to install windows 7 or later on an LG Netbook with no DVD player?
СообщениеДобавлено: 05 окт 2015, 03:30
ZALMAN ZM-VE300 http://www.zalman.com/global/product/Pr ... hp?Idx=674
or any USB flash drive and grub loader
СообщениеДобавлено: 10 окт 2015, 18:34
I can not install windows 7 on LG X140 Netbook
As there is no DVD player in the Notebook I had to prepare a bootable pendrivel using Rufus software.When it arrives in the completion of the installation of Windows 7 get a blue screen and reset the machine. I tried to run it in safe mode, but it Reached Classpnp.sys And Then rebooted.
I'm guessing is missing the video file from Netbook that should be within the Windows 7 installation DVD
СообщениеДобавлено: 17 окт 2015, 06:12
I think I located the problem of this netbook from LG X140 has a chip that sits between the memory slots, USB connectors and the cooler that is heating up enough. Does anyone know the chip function?
The platform of this motherboard is the code: DAOAX2MB6E1 REV: E1 Hannstar
СообщениеДобавлено: 18 окт 2015, 13:47
2gb is not enough for complete (unstripped) Windows 7 distribution. You can create a fat32 partition on your HDD and copy installation files there, the partition has to be active.
СообщениеДобавлено: 26 окт 2015, 20:27
I suspect the difficulty installing Windows 7 or any operating system with the exception of XP is on the Hardware. I would like to do a check on hardware, what better program to use preferably Linux and how to create the boot via pendrive?
СообщениеДобавлено: 27 окт 2015, 11:23
Have you tried to install other versions of the operating system Microsoft (XP, 8, 8.1, 10)?
"...В процессе ремонта вашего ноутбука... что-то пошло не так... рекомендуется заменить материнскую плату" (С) один сервис-манагер :)
 Заголовок сообщения: Re: Is there an alternative to install windows 7 or later on an LG Netbook with no DVD player?  [РЕШЕНО]
СообщениеДобавлено: 28 окт 2015, 15:36
The difficulty of installing any operating system other than XP was in two inner bent pin soldier connector on the motherboard where the cable is placed flat LCD screen. Repair done, now I can install the operating system, I came to install Ubuntu 14 by the virtual stick and everything normal. As before a physical test on the video controller using Linux if there is a Linux program that can do this test in the video controller.
В этой теме нет новых непрочитанных сообщений. Msi R7 370 2g armor turns on and off 2 seconds later
TheMArcos
1825
10 май 2020, 20:16
TheMArcos Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. 216-0833000 & 216-0855000 vga chip alternative
serwanjaf7
3785
20 мар 2017, 16:38
Azazehl Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gtx520m alternative
в форуме temp
serwanjaf7
11 апр 2020, 21:35
serwanjaf7 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. dell vostro 1520 (LA-4595p) windows won't install
в форуме Dell
nasser_pczone1
3023
05 авг 2019, 19:51
nasser_pczone1 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. asus (x550jx) cant install windows
narges
29 авг 2019, 01:04
Kim_555 Перейти к последнему сообщению
