Текущее время: 18 июн 2024, 15:12
 Заголовок сообщения: Compaq 6735s (6050A2235601-MB-A03) 1st MOSFET doesn't turn on
СообщениеДобавлено: 05 янв 2016, 12:46
Hi everybody.
there is a Compaq 6735s (6050A2235601-MB-A03) motherboard that with adapter connected there isn't any voltage on the mobo.
inspected the schematics and found that the main mosfet is Q1031 which let's the current flow through circuit, but it's not on, so there isn't any voltage available, although there is 19.5v at source and 19v at gate (you can see in the picture attached). but when i touch the gate pin of Q1031 with my finger (naturally there is a voltage drop at gate), mosfet turns on and current passes through. I then desoldered Q1031 and shorted source to drain on the mobo and notebook started operating without problems. I checked the nearby components although not all of them but the ones I checked are OK.
I don't know why this mosfet doesn't turn on. maybe 0.5v voltage difference on S-G is not enough. Any help will be appreciated.
thanks in advance.
 Заголовок сообщения: Re: Compaq 6735s (6050A2235601-MB-A03) 1st MOSFET doesn't turn on
СообщениеДобавлено: 05 янв 2016, 20:50
Chek these signals:
ADP_EN# must be 0V.
BUTCAL# must be 0V.
СообщениеДобавлено: 05 янв 2016, 21:32
novapc писал(а):
Chek these signals:
ADP_EN# must be 0V.
BUTCAL# must be 0V.
Thanks for the reply.
ADP_EN# is 19v
BATCAL# is 18.3v
in order to operate normally, should they be zero?
СообщениеДобавлено: 06 янв 2016, 11:32
FRD писал(а):
ADP_EN# is 19v
BATCAL# is 18.3v
I think so.
Update BIOS, and try to chek CHGCTRL_3. May by KBC1091 (118 pin) do not generate this one.
СообщениеДобавлено: 06 янв 2016, 13:52
Will try the BIOS, but I think it's not BIOS related, because in current state there isn't any voltage available on board and all BIOS IC pins are 0v, so BIOS is not readable at all in current situation, but when I short Q1031 source to drain, voltage becomes available and I can turn on the laptop normally.
Also checked KBC pin 118, there is nothing there, 0v.
Thanks and I really appreciate the time and effort.
СообщениеДобавлено: 06 янв 2016, 14:31
You have no +VBAT. Chek ADP_PWRID and LIMITsignal. Maybe U1024-A is out of order.
СообщениеДобавлено: 13 янв 2016, 09:46
Thanks and sorry for the late reply, I wasn't able to post for a couple of days. I will check.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Compaq 6735s (6050A2235601-MB-A03) автостарт
romexsrv
06 сен 2016, 14:06
0verflow Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. compaq 6735s (6050A2235601-MB-A03) не регулируется подсветка
Toxa1111111
18 фев 2017, 19:37
Toxa1111111 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP Compaq 6735s (Inventec 6050A2235601-MB-A03) не включается
blackflash
03 июн 2018, 10:31
InsideMan Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. compaq 6735s (6050a2235601-mb-a03) нет реакции на кнопку включения
masterjaknotebook
22
3237
15 июл 2019, 11:08
masterjaknotebook Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. compaq 6735s (6050a2235601-mb-a03) Уже вкл. но дальше биоса не грузится
brenden
02 фев 2021, 09:16
Сейчас этот форум просматривают: astryzheus, dinyasoft, Google [Bot], hyperion5, Kramator, Lex-, ruzalit и гости: 29
