Текущее время: 27 июн 2024, 09:41
 Заголовок сообщения: X550D (X750DP r2.0) Не вкл. , КЗ или кусок схемы
СообщениеДобавлено: 27 окт 2015, 08:56
Подскажите что за 6ти ногий зверь
http://eximage.ru/image.php?di=WXPX
написано на ней AE3TB
 Заголовок сообщения: Re: X550D (X750DP r2.0) Не вкл. , КЗ или кусок схемы
СообщениеДобавлено: 27 окт 2015, 09:11
SY8065ABC
СообщениеДобавлено: 06 янв 2016, 11:33
hi all. i have an asus with mb: x750dp rev:2.0 with burned IT8528e, i replaced this ic with new one and now when i plug power cord laptop make a power cicle, one led lights out but no image, no cooler activity, when i press power button it doesn't make anyting.
if i put battery on mb no led, no power cicle.
on bios is on pin 1 i have nothing, only on pin 3 i have 3.3 v
anybody know what could be the problem? i read somewhere that it8528e must be programed but i do not have dump and i don't how how to do that, i have an ch342a usb programer but i don't reprogramed this king of ic by now.
СообщениеДобавлено: 06 янв 2016, 13:23
tell me, what power on pin 8 on bios ic?
Профессиональный ремонт ноутбуков и моноблоков в Екатеринбурге, т. 372-23-60
СообщениеДобавлено: 06 янв 2016, 14:20
on pin 3, 7, 8 i have 3.3v
СообщениеДобавлено: 06 янв 2016, 16:16
When you plug battery, charge indicator light on?
СообщениеДобавлено: 06 янв 2016, 16:20
not programmed
СообщениеДобавлено: 06 янв 2016, 16:29
when i plug battery no light come on. only when is only on ac lights on first led but i can't power on.
СообщениеДобавлено: 12 янв 2016, 16:47
update: i measured motherboard and i found that an chip TPS51225C is very hot when i put finger on him, i measured next values:
vbst1: 10.11v
drvh1: 5.65v
en1: 3.36v
vclk: 2.75v
sw1: 5.58
cs1:0.81
vfb1:2.07
vreg3: 3.37
vfb2:0
cs2:0.89
en2:0.08
pgood:0.0
sw2:0.00
vbst2:5.00
drvh2:0.0
drvl2:0.0
vin:19.37
vreg5:5.20
vo1:5.20
drvl1:0.26
and still i don't have 3.3 on pin 1 on bios chip , instead i have 3.3v on 3rth pin
could be the problem from TPS51225C?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS X550D (X750DP) не включается
IG67
08 дек 2014, 18:21
IG67 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus x550D (x750DP Rev: 2.0) Залитый
geroinn
5920
02 дек 2014, 19:16
geroinn Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus X550D (X750DP rev.2.0) Не включается.
Andreyanov
17
9028
10 мар 2018, 18:14
Tasik Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus x550D (x750DP Rev: 2.0) Замена RTD2136R на RTD2132S
storm23rus
05 дек 2014, 16:53
storm23rus Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS X550D (X750DP rev: 2.0) Нет подсветки!
xomjak
12
9316
02 янв 2015, 06:18
xomjak Перейти к последнему сообщению
Сейчас этот форум просматривают: achsel, noobon, ruzalit и гости: 71
