Текущее время: 16 июн 2024, 07:24
 Заголовок сообщения: Toshiba L50-B-12G (DABLIDMB8E0) R391 Burnt
СообщениеДобавлено: 25 мар 2016, 20:55
Hello, second time I get a Toshiba L50-B with the R391 burnt, I've tried switching the KBC but I don't know the value of the resistor.
Motherboard: DABLIDMB8E0 REV:E
KBC: Nuvoton NPCE985LA0DX
GPU: 216-0858020
The problem is the same as in this post: http://www.elektroda.pl/rtvforum/topic3089829.html - But the problem is that I cant understand the translation and also I don't have any diagram to find out what resistor I need to place there.
Could someone please help?
Saber é poder "knowledge is power"
 Заголовок сообщения: Re: Toshiba L50-B-12G (DABLIDMB8E0) R391 Burnt
СообщениеДобавлено: 25 мар 2016, 22:39
At Polish forum this problem was solved as follows: the KBC has been replaced and burned resistor has been replaced to zero ohm resistor.
СообщениеДобавлено: 25 мар 2016, 23:00
Ok, will try that first thing tomorrow morning.
---------- Добавлено спустя 8 минут 1 секунду: ----------
Do you think SMD 1206 4.7Ohm 250mW will do? It was the lowest I found.
Was looking on scrap motherboards but could not find anything lower.
СообщениеДобавлено: 25 мар 2016, 23:36
I think it will be ok.
СообщениеДобавлено: 08 апр 2016, 20:31
This is kept without solution. Can't find where is the short-circuit. Have another equal computer working and found that the resistor is really 0ohm. Any ideas? I already pluged a power suply to find our where the problem is, but no success.
---------- Добавлено спустя 19 минут 7 секунд: ----------
Found out what is heating up... Its the CPU at 0.9V with 4.5A.
Now what? Any recomendations?
Its an i5-4200U.
In the working Motherboard, there is no consumption on the R391.
СообщениеДобавлено: 12 апр 2016, 22:14
Hello,
Still no solution on this?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba Satellite L50-B-169 (DABLIDMB8E0) Нужен биос
в форуме Toshiba
cunamis
18 май 2016, 20:55
cunamis Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba SATELLITE L50-B-19l (DABLIDMB8E0-rev:E) нужен дамп биоса
в форуме Toshiba
djdron
11
5986
25 сен 2016, 16:37
AL._.EX Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba Satellite L50-B-171 ( Quanta DABLIDMB8E0 REV:E) Автостарт платы, нет изображения
в форуме Toshiba
DELLIS
3601
16 сен 2017, 02:28
makar303 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba L50-B-1TD (dablidmb8e0 REV:E) Старт без видео
в форуме Toshiba
Ronin73
10 июл 2017, 16:37
Ronin73 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba L50-B-175 (DABLIDMB8E0 Rev E) ME region
в форуме Toshiba
Dionisiy
18 июл 2017, 17:55
