atamanul писал(а):
When running on battery displays the following message-
The computer is docked and only battery power is detected. this can happen if the power adapter is missing, the power cord is unplugged, or the computer is not properly connected to the docking station. you should undock, redock, attach the power adapter, or plug in the power cord.
Strike the F1 key to shutdown.
Im not using the docking procedure
When turned on the power supply is working properly. may be a malfuction on the motherboard?
Вы проверить зарядное устройство раздел на материнской плате?
