Текущее время: 28 ноя 2026, 14:25
 Заголовок сообщения: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error
СообщениеДобавлено: 14 июн 2016, 11:38
Hi guys,
There is this notebook which turns on but is stuck at boot screen with error
0177 Bad SVP Data
searched on he forum and couldn't get that much info, is there anything I can do for this?
thanks in advance.
 Заголовок сообщения: Re: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error
СообщениеДобавлено: 14 июн 2016, 18:31
Put a dump of 24s08 up
СообщениеДобавлено: 17 июн 2016, 11:39
Thanks for the reply, the laptop itself is not here at the moment, but it'll be in my hands in a couple of days, as soon as I get it I'll post up the dump.
Thanks.
СообщениеДобавлено: 21 июн 2016, 12:02
Ok, I got the notebook and take out the motherboard, found NXP P24S08 and put it in the programmer, when I select the chip in programmer software it says these ics have read protection and when I read the IC it gives all 0xff, only a few bytes around 0x400 address has some data, I think these are read protection blocks, am I correct? so any guide on how to proceed?
Note: My programmer is TNM2000+
thanks in advance
СообщениеДобавлено: 21 июн 2016, 17:06
As
Цитата:
The eeprom is a Philips P24S08 which is equivalent to a 24RF08, so any reference in the following text to a 24RF08 applies to this eeprom
it is a good idea to dance around with 24rf08 and IBMPass.
СообщениеДобавлено: 22 июн 2016, 13:20
Rein писал(а):
As
Ok, as it seems someone else before me has wiped 24s08, because when i read it gives me all 0xff, if it's been erased completely, can I do something?
СообщениеДобавлено: 14 июл 2016, 15:45
guys I have found a BIOS and 24s08 dump from forum in the following link.
viewtopic.php?f=58&t=6140&p=345131&hilit=%2At61%2A#p345131
I have programmed both BIOS and NXP 24s08 and now bad SVP data error is not shown and I can boot and work with system, however every time I restart the laptop it gives and Error as Follow
Error
0188 : Invalid RFID Serialization Information Area.
Press <F1> to Setup
although I press ESC and windows boots, but it's annoying, as it seems it's related to EEPROM CRC checksum and board Serial number, Am I correct? I have played with DMI values in Winphlash advanced setting with no luck :(
Any help will be appreciated.
Thanks an advance.
СообщениеДобавлено: 14 июл 2016, 20:06
FRD change serial`s with Lenovo HMD
СообщениеДобавлено: 15 июл 2016, 08:11
Sergej Thanks for the answer, but right after i posted, i found the HMD and made a USB Flash Key, I managed to change system-unit and system board serial numbers, the previous ones were corrupt. Now serial numbers do appear on BIOS screen and error 0188 is gone for good now and system boots normally, but I can not change MAC Address (Internal LAN) on BIOS. It's all FF FF FF FF FF FF. I have tried it with C1 and C2 locations with no luck, is there a manual for HMD somewhere? Maybe I'm not feeding the MAC Address with the correct prefix?!!
СообщениеДобавлено: 15 июл 2016, 19:27
i wrote old MAC (from original dump) manually in a new BIOS with HEX-editor and then programmer.
СообщениеДобавлено: 17 июл 2016, 07:42
Spent some time in HEX-editor looking for MAC addresses in BIOS dump with no luck, I think MAC address is not stored in BIOS, instead it's in 24s08 dump, because when I open 24s08 dumps in SVP Tool it gives me, unit serial no, system board serial no, UUID and MAC address also.
I'm attaching dumps and some pictures, and I really appreciate if you have the time to check.
T61 Files
Thanks you so much.
В этой теме нет новых непрочитанных сообщений. Lenovo ThinkPad T61 (-) Error 0192 - System Security - Embedded Security hardware tamper detected.
Wikl
04 окт 2019, 00:34
В этой теме нет новых непрочитанных сообщений. Bad Memory Channel or bad Mem chip?
donught
21 мар 2023, 15:42
bd250 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo Thinkpad E560 SVP Password ?
AccountSaver
08 авг 2018, 20:24
AccountSaver Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ThinkPad X1 Carbon 8th Gen (NM-C881 Rev:1.0) Сброс пароля супервизора (SVP)
Yurij_Юр
656
10 ноя 2026, 01:42
Sentox Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ThinkPad X1 Carbon 6th Gen (Compal/LCFC) Сброс пароля супервизора (SVP)
Sentox
10 ноя 2026, 16:41
Сейчас этот форум просматривают: ->SV<-, Haik и гости: 93
