Текущее время: 09 май 2024, 21:48
draganzile
Заголовок сообщения: Fujitsu LifeBook NH532 (Intel i5 3230m Nvidia 640m LE) Problem with RAM memory , also Problem with Graphic dri Добавлено: 31 июл 2016, 22:07 |
Зарегистрирован: 23 май 2016, 11:48 Наличности на руках: 63.07
Сообщения: 52 Откуда: Croatia
OK, here i got laptop Fujitsu LifeBook NH532
Had bios corruption, managed to reset bios by resetting CMOS
Then assembled the laptop and the problem occured. When i put 2gb memory inside of the RAM slot (has 2 ram slots) it works, but when put another memory inside, will not show picture. also, when i put single 4gb ram module in any slot, there is no picture.
i have tried all 1.5v memory ( guess its 1.5v couse i can see 1.5v on ram slot) another problem is that the graphic card (intel 4000 from cpu and nvidia 640m le ) when running windows 10 and instal any version of nvidia drivers laptop will FREEZE , only will work on win 8 or win 7. (guess fujitsu driver support is crap)
anyways, can anyone tell me why isnt this laptop working with 2x2gb ddr3? or 1x4gb ddr3? i did not get any memory with the laptop ... any suggestions? help please.
KcapDac
Заголовок сообщения: Re: Fujitsu LifeBook NH532 (Intel i5 3230m Nvidia 640m LE) Problem with RAM memory , also Problem with Graphic Добавлено: 31 июл 2016, 22:15 |
Зарегистрирован: 20 дек 2013, 09:21 Наличности на руках: 449.61
draganzile писал(а): any suggestions? First of all you should specify platform of notebook. Try install good CPU (may be it solve problem with RAM modules). draganzile писал(а): when running windows 10 and instal any version of nvidia drivers laptop will FREEZE , only will work on win 8 or win 7 Win 10 is a piece of shit
draganzile
Заголовок сообщения: Re: Fujitsu LifeBook NH532 (Intel i5 3230m Nvidia 640m LE) Problem with RAM memory , also Problem with Graphic [РЕШЕНО] Добавлено: 01 авг 2016, 13:29 |
Platform Fujitsu FJNBB2F Chipset IvyBridge , HM77
Current processor is i5 3230m (processor which came with laptop )
i have installed windows 7 now and everything works just cant instal more then 2gb memory single channel :D
any ideas? i can try to replace the cpu and then try to instal more memory. i have opened the laptop , inspected the chips, but nothing looks burned.
maybe i should try to update bios? Posted after 3 hours 34 minutes 47 seconds: Re: Fujitsu LifeBook NH532 (Intel i5 3230m Nvidia 640m LE) Problem with RAM memory , also Problem with Graphic dri ok, changed cpu to i3 3130m and i7-3630qm , works fine but again cant get more then 2 gb memory :D
really dont know what could it be?
gonna try to upgrade the bios next. any other useful opinions guys? anyone?
guess its not the problem with memory power supply couse 2gb works ok in any slot... also have tried ddr3 L and ddr3 1.5v memory...
Posted after 1 hour 3 minutes 33 seconds: Re: Fujitsu LifeBook NH532 (Intel i5 3230m Nvidia 640m LE) Problem with RAM memory , also Problem with Graphic dri ok, it all works now after bios update, problem solved :)
can be closed. thanks for watching my russian friends
