Текущее время: 23 май 2024, 10:43
Shooter75
Заголовок сообщения: Re: A1502 (820-3476-A) Can not read 25Q064A Добавлено: 13 окт 2016, 11:48 |
Зарегистрирован: 23 фев 2011, 12:57 Наличности на руках: 2,195.34
Problem is in 1,8Vcc at "Q" series chips.
I modified my 5VDC SOIC8 ZIF adapter. 1. I cutted VCC line from ZIF to DIP. 2. Added in line two diodes in sequence, it make voltage drop approximative 1.4V 5-1,4 = 3,6v 3. Added a jumper between ZIF Vcc and DIP Vcc pins. It restores 5Vcc in other cases. 4. And then I added another line of two diodes in cutted Vcc line and added one more jumper. 3,6V-1,4V=2,2V This is enough to operate with "Q" series SPI FLASH ROMs.
In total I made power bus in this mode:
[2,2VDC] ZIF-Vcc-|<|-|<|-.[3.6VDC].-|<|-|<|-DIP-Vcc [5VDC]
And all works excellent!
