Текущее время: 06 июн 2024, 13:46
 Заголовок сообщения: MSI laptop GP60 (MS-16GH1 ver. 1.0) almost dead
СообщениеДобавлено: 31 авг 2016, 20:59
Hi,
I have a MSI laptop GP60. (motherboard MS-16GH1 ver. 1.0)
3.3 and 5 volts are missing, and only there are pulses in ec-bios. (U9)
Pin 1 of ec-bios seems to have a repetitive pattern of pulses, that changes when I push power button.
As I mentioned, pulses changes but only for 3 or 4 seconds, then return to initial state.
3.3 rail, has a resistance of 2500 ohms, so there is no short, but if I inject voltage with a bench power supply, the PCH chip gets hot, with only 1,1 volts on 3,3v rail.
It seems to me that pch (u17) is damaged, but.....
Any suggestions?
Anybody has schematic for this motherboard or boardview? (or any schematic which helps)
PD: ec-bios has been programmed.
В сети
 Заголовок сообщения: Re: MSI laptop GP60 (MS-16GH1 ver. 1.0) almost dead
СообщениеДобавлено: 17 окт 2016, 16:49
Hi i also cant find schematic. Can you measure EN1 and EN2 signals in 3.3/5V converter? What is power consumption on laboratory power supply. Propably you are right about PCH. ON photo i see coil and 2 mosfets neer by PCH measure resistance coil to GND.
Posted after 1 hour 27 minutes 22 seconds:
Do you know how to do the short-test which laboratory power supply?
If you can, you can remove coil in 3.3v and put voltage 3.3v, 500mA from laboratory power supply to coil pad if power compsumtion will be 500mA check PCH is he hot, if not pull up current 100mA untill you feel temperature on PCH. Then remove PCH and do another shortcut test.
There is some information how to do short-test on this forum.
https://www.elvikom.pl/szkolenie-nr-1-p ... -t986.html
В этой теме нет новых непрочитанных сообщений. MSI GP60 (MS-16GH1 ver 1.0) need bios dump
в форуме MSI
notemaster
22 окт 2016, 23:01
metal61 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. msi gp60 (ms-16gh1 ver 1.0) нужна схема
в форуме MSI
red deer
14
6303
20 июн 2019, 18:52
chdim Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI GP60 (MS-16GH1) Циклическое замирание изображения
в форуме MSI
fred24
19 фев 2017, 15:29
Денис Скляров Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI GP60 (MS-16GH1) Не включается. Родной блок уходит в защиту
в форуме MSI
provista911
02 фев 2017, 18:00
provista911 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI gp60 2pf leopard pro (Ms-16gh1) Нет изображения
в форуме MSI
makar303
26 июл 2018, 19:49
makar303 Перейти к последнему сообщению
Сейчас этот форум просматривают: Sokol8989 и гости: 8
