Текущее время: 21 ноя 2024, 22:34
 Заголовок сообщения: Asus K51AC (AMD) Bios password?
СообщениеДобавлено: 30 окт 2016, 20:16
Hello,
can someone help me to get my Asus K51AC BIOS password ... Bios version is 209 and Bios date is 07/15/09.
Bought used laptop, but I cannot enter bios ...
Thank you in advance
Grega, Slovenia
 Заголовок сообщения: Re: Asus K51AC (AMD) Bios password?
СообщениеДобавлено: 30 окт 2016, 21:03
remove cmos battery to 3 minutes. if doesn`t help reflash bios from recovery disk.
СообщениеДобавлено: 30 окт 2016, 21:06
Try 2BB1LBA1
В личке все ответы платные.
СообщениеДобавлено: 30 окт 2016, 21:26
gofer писал(а):
Try 2BB1LBA1
Not working...
СообщениеДобавлено: 30 окт 2016, 22:05
remove cmos battery not solve problem?
СообщениеДобавлено: 30 окт 2016, 23:04
No and also flashing did not help. Password still on...
СообщениеДобавлено: 30 окт 2016, 23:09
One variant solve the problem - reflash bios from bios dump which downloaded from another k51ac notebook
СообщениеДобавлено: 31 окт 2016, 11:38
remote bois battery on 2-3 days, because matherboard have condensators, and they take charge. wait when they have worn
СообщениеДобавлено: 31 окт 2016, 12:40
I think it won't work, because when I took battery out, I also shorted + and - for few seconds, and pushed power button for 10 seconds ... that should discharge capacitors ...
I got bios dump, how can I flash it? Do I need hardware flasher for that?
СообщениеДобавлено: 31 окт 2016, 12:45
Yes, you need programmer like a ch341. You can buy it from ali or ebay.
Regards.
СообщениеДобавлено: 31 окт 2016, 14:01
I managed to flash bios dump with asus flash utility (with /nodate) option ... but it seems that password is not stored in cmos, but in eeprom, and If I flashed bios 1000 times, still will remain ..
СообщениеДобавлено: 31 окт 2016, 14:56
Bios ic need flash in special programmer for spi flash.
СообщениеДобавлено: 31 окт 2016, 15:00
This device(ch341) can write eeprom. I don't have schematics of your motherboar, but I think bios password must be in bios flash. If you will write clean bios with programmer it will resolve your problem.
СообщениеДобавлено: 31 окт 2016, 17:09
Ok, just in case I contacted Asus - waiting if they will reply - if they have some kind of master password ... if they don't then only way is to buy flasher and try that.
Thanks all, for your help.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. K51AC (K51AC) Bios password needed.
grzewoj
16 июл 2018, 17:03
grzewoj Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS K51AC (K51AC rev2.1) растет SMART Ultra DMA CRC Error Count
Ilkapone
15
4025
25 май 2019, 15:29
Boglen Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. K51AC (K51AB) BIOS password needed.
grzewoj
17 июн 2016, 14:07
В этой теме нет новых непрочитанных сообщений. Toshiba Tecra Z30-A (BIOS PASSWORD) BIOS PASSWORD
в форуме Toshiba
vnn567
23 авг 2017, 08:07
vnn567 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Latitude 3340 (Password) how to remove password
в форуме Dell
nafienew
17 мар 2015, 08:04
evserv Перейти к последнему сообщению
Сейчас этот форум просматривают: Saxet и гости: 72
