Текущее время: 09 ноя 2026, 19:56
 Заголовок сообщения: ASUS GL702VM-DB71 (GL702VM-DB71) Bios Problem  [РЕШЕНО]
СообщениеДобавлено: 23 ноя 2016, 20:18
Hi. After bios update notebook don't turn on screen. I think bios update failed. So I need to reprogram bios.
I need bios of ASUS GL702VM-DB71. This is so new notebook. I wish you can help to find. Thank you.
 Заголовок сообщения: Re: ASUS GL702VM-DB71 (GL702VM-DB71) Bios Problem
СообщениеДобавлено: 26 ноя 2016, 16:24
Hi, I have same model with the same exact problem. Was it easyflash failing to verify? I've pm'd you, please check.
СообщениеДобавлено: 26 ноя 2016, 19:28
I think you can download bios update from Asus site, put it on a flash drive formatted with fat32. Then turn off the notebook, put flash drive into usb, press and hold CTRL+HOME and turn on. Wait while led indicator on flash (if it has) starts blinking. Good luck.
СообщениеДобавлено: 26 ноя 2016, 19:41
Tried that already, it doesn't read from the usb unfourtunately. Usb light comes on for a milisecond and turns of. Tried different kind of flash drives too. :-(
СообщениеДобавлено: 27 ноя 2016, 22:35
When you turn on notebook, do you see hdd led blinking for a short time with pressed ctrl+home? If yes then it tries on hdd. If you still have the original windows installed, the backup copy of your bios placed in the root of C:\
If you don't reinstalled you can do the CTRL+HOME routine try it several times. And don't forget that reflash takes several minutes.
I'd been repairing one old asus and it didn't take bios from flash too. Had to disassembly it, resolder flash spi and flash onto Programmer.
Did it happen after you'd tried to update bios or not? Maybe there is another reason.
СообщениеДобавлено: 29 ноя 2016, 21:36
USB Flash drive must been format in FAT16. Copy bios files to flash drive. Rename you bios files in AMIBOOT.ROM or AMIBOOT.BIN.
Power OFF
Power cord must been OFF
Battery switch OFF remove from notebook.
Insert Flash drive into USB port 2.0, or which support
Press <Ctrl> + <Home> or <FN>+<R>
Switch power cord into notebook
Press power button
If your flash drive flash all is OK and whaiting restart.
СообщениеДобавлено: 29 ноя 2016, 22:13
По гуглу у него несъемная батарея. Восстанавливается эта серия через хоум, я на g75 и g750 экспериментировал.
СообщениеДобавлено: 30 ноя 2016, 08:45
GL702VM
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GL702VM-DB71 (GL702VM Rev. 2.0) Помоготите определить полевик
Veld
06 июн 2019, 14:12
Veld Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus GL702VM (GL702VM) GTX 1070 вместо GTX 1060
wentel6
15
5396
23 сен 2020, 13:19
Boglen Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus GL702vm (gl702vm rv2.0) не работает клавиатура
Маньяк
27 май 2021, 09:03
Маньяк Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus GL702VM (GL702VM) Нестабильный старт
inertic
2028
12 окт 2021, 15:57
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus GL702VM (GL702VM rev 2.0) +VCCSA 2.45v
stalker310200
16 апр 2022, 12:00
stalker310200 Перейти к последнему сообщению
Сейчас этот форум просматривают: A999S, Google [Bot] и гости: 82
