Текущее время: 21 ноя 2024, 22:23
 Заголовок сообщения: A1466 Early 2015 EFI (OS X) efi pinout
СообщениеДобавлено: 29 ноя 2016, 00:49
Hello
can someone provide efi pinout on logic board to flash the bios chip?
i try like this but can`t read the chip
MacBook Air "Core i5" 1.6 13" (Early 2015)
1.6 GHz Core i5 (I5-5250U)
Intro. March 9, 2015*
Order MJVE2LL/A*
Model A1466 (EMC 2925)
Family: Early 2015
 Заголовок сообщения: Re: A1466 Early 2015 EFI (OS X) efi pinout
СообщениеДобавлено: 29 ноя 2016, 01:34
Chip pinout is same with standard DIP8/SOP8/SO8 SPI chips.
Connector pinout is in attached picture.
But the best way is to desolder the chip, solder to programmer adapter DIP8, or use a "crocodile"-type adapter,
reprogram chip using the SPI programmer, and then solder it back to MoBo.
If You can't do this - better will be to try it in any serious IT service center.
СообщениеДобавлено: 29 ноя 2016, 01:51
thanks for that
do you maybe know why this guy use some kind of test point on another side of the board
СообщениеДобавлено: 29 ноя 2016, 02:01
It's not a some kind of test points, it's an in-system SPI programmer with special UEFI dump.
Time for repairing UEFI PWD lock is same with total 64Mb SPI reprogramming time with new, good SPI programmer, based on CYPRESS MCU.
I do this job not in 15 secs, but in 10 minutes. I use very old SPI programmer WILLEM2000 LPT.
It works nice, and I don't want to change them.
СообщениеДобавлено: 03 дек 2016, 02:46
unsolder you the chip or are you using this isp connector with your programmer?
СообщениеДобавлено: 06 дек 2016, 01:48
I think to buy isp connector but for a reasonable price (if someone knows place to buy please share)
this time i will try to find alternate points to solder on board or reomve chip with hotair.
Posted after 1 hour 6 minutes 49 seconds:
final pinout from boarview
В этой теме нет новых непрочитанных сообщений. Air A1465 early 2015 (820-00165-A) Иногда долгий старт и не догружается
в форуме Apple
_AVP_
2830
16 июл 2016, 21:44
andriyd1 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A1534 (early 2015) A1534 вопрос по клавиатуре
в форуме Apple
vampirekiller
21 дек 2018, 20:35
Dejmos Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. A1502,Retina,13-inch,Early 2015 (820-4924-a) Не управляет вентилятором
в форуме Apple
VVS987
14 фев 2019, 02:32
VVS987 Перейти к последнему сообщению
в форуме Apple
VVS987
09 фев 2019, 21:11
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. macbook pro 13" early 2015 A1502 (661-02359) нет изображение, попадание влаги
в форуме Apple
jwayne26
23 июл 2020, 15:05
jwayne26 Перейти к последнему сообщению
Сейчас этот форум просматривают: ArsVA и гости: 37
