Текущее время: 22 ноя 2024, 10:08
 Заголовок сообщения: Macbook Isp Programmer (Isp Programmer) Macbook efi password
СообщениеДобавлено: 03 дек 2016, 02:57
I wanted to know is there a good Programmer on the market who can program efi chips from macbooks without unsoldering the chip using the Isp connector?
i'm currently using raspberry pi but for 2015 model pro and air it doesnt work, i get different efi dumps.
 Заголовок сообщения: Re: Macbook Isp Programmer (Isp Programmer) Macbook efi password
СообщениеДобавлено: 05 дек 2016, 09:19
Different pinout in new models can appear. Compare pinouts and modify rasPI programm.
СообщениеДобавлено: 05 дек 2016, 21:35
thank's for your reply, but i wanted to know if there
is a better programmer to work with this macbooks.
raspberry works fine till 2014 models but works very slow
and for 2015 models it doesnt read good (get different dumps)
i have also sofitech -16B and Mini programmer but onboard efi program is impossible, must unsolder chip
СообщениеДобавлено: 07 дек 2016, 19:12
If You know programming of CYPRESS MCUs, they has native hi speed SPI interface in some models.
For highest speed You need to use 4 bit mode of SPI @ 33MHz clock = 133Mbps data exchange speed.
Or reprogram your procedures in RasPI.
СообщениеДобавлено: 12 дек 2016, 22:23
Sorry for my bad english,
but i ment instead of programming with raspberry i need another programmer who can program macbooks 2015 models without unsoldering the efi chip and using the clip.
I have the Sofi SP-8A and SP-16B and the mini programmer but they all do not work with this clip due power problems.
СообщениеДобавлено: 12 дек 2016, 23:18
All You need, to make adapter with bus drivers, which can drive more than 1 chip on bus.
СообщениеДобавлено: 19 дек 2016, 17:35
Саn you please tell more about how you programm 2013-2014 models EFI's with Raspberry? What soft do you use?
---------- Добавлено спустя 5 минут 2 секунды: ----------
And what port? GPIO?
СообщениеДобавлено: 20 дек 2016, 00:32
First at all my condolences for mine russian friends for this terror action!!
I use Flashrom with raspberry. Look at here for more info
https://ghostlyhaks.com/blog/apple-efi/ ... ?showall=1
СообщениеДобавлено: 20 дек 2016, 00:40
Thank you!
В этой теме нет новых непрочитанных сообщений. A1466 Early 2015 EFI (OS X) efi pinout
в форуме Apple
niktele
06 дек 2016, 02:55
niktele Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Apple Macbook Air (OS X) Remove efi password from this file
в форуме Apple
niktele
12 дек 2016, 11:38
В этой теме нет новых непрочитанных сообщений. A1466 (820-3437-B) после EFI password вкл только в SafeMode
в форуме Apple
apollo
25 сен 2015, 22:13
gnommak Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. A1534 ( 820-00045) EFI password
в форуме Apple
fediabegen
05 июл 2016, 01:05
fediabegen Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A1418 (MAC OS) A1418 EFI password
в форуме Apple
FireFx
17 сен 2017, 13:48
Alex_1234 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 32
