Текущее время: 08 ноя 2026, 01:38
 Заголовок сообщения: Apple A1534 (820-00045-10) No response on power
СообщениеДобавлено: 26 янв 2017, 14:56
this mac came with black screen, i press sw6900 to switch-off the battery and when i corrected the lcd cable, connect power supply mac started with contents on screen and there is login screen and the battery status is 24% i did not have connect keybard so i turn off the power supply since then my mac dos not response on power button, i tryeed to reset smc and nvram but no resoult, what i can do ?
 Заголовок сообщения: Re: Apple A1534 (820-00045-10) No response on power
СообщениеДобавлено: 26 янв 2017, 15:22
you can download schematics and take measurements
СообщениеДобавлено: 06 фев 2017, 17:05
sorry i have no time to reply, and did it and there is only PP3V3_S5 i checked all coils and i describe everything in photo
СообщениеДобавлено: 06 фев 2017, 18:19
...make measurements. And then - give them to us.
POWERS SYSTEM ARCHITECTURE - is the best start point.
SMC and Broadwel PCH side livability will resolve Your problem.
Check and change all PWM controllers one by one, if You are sure in SMC, UEFI and Broadwell.
СообщениеДобавлено: 06 фев 2017, 20:48
Shooter75 писал(а):
take measurements
унаследовано от "take action"!
"делай чтото" а не вот мамка, фоточка, ничё не работает, памагите
да еще время нету :)
СообщениеДобавлено: 06 фев 2017, 23:52
"G3Hot" (Always-Present) Rails
PPBUS_G3H - 8,3
PPVIN_G3H_P3V3G3H = 14,9V
PPBUS_S5_HS_COMPUTING_ISNS - 8,3V
PPVBUS_E85 - 14,9V
PPDCIN_G3H - 14,9V
PP3V3_G3H - 3,3V
PP3V3R3V0_AON - 3,3V
PPVRTC_G3H - 3,3V
5V Rails
PP5V_G3H_LDO - 5,0V
PP5V_S0SW_LCD - 0V
PP5V_S4 - 5V
PP5V_S0 - 8,3V
3.3V Rails
PP3V3_S5 - 3,3V
PP3V3_SUS - 0v
PP3V3_S4 - 0V
PP3V3_S0 - 0V
USB-C PWR (5.1V)c
PP5V1_S4SW - 2,4V
1.8V/1.5V/1.2V/1.05V Rails
PP1V8_S3 - 0v
PP1V5_S0 - 0v
PP1V2_S3 - 0v
PP1V05_SUS - 0v
PP1V05_S4SW - 0v
PP1V05_S0 - 0V
PP1V05_S0SW_PCH_PCIE - 0V
SSD Rails
PP3V3_S0SW_SSD - 0V
PP3V3_S0SW_S1X - 0V
CPU "VCORE" RAILS
PPVCC_S0_CPU - 0V
СообщениеДобавлено: 07 фев 2017, 18:20
the next step will be flash bios but there is no any, so what can i do now ?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Apple (BIOS) Apple A1534 820-00045-11 нужен BIOS dump
в форуме Apple
Gasasoft
22270
26 авг 2019, 08:32
vzrivpaket Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Apple A1534 (820-00045) 0,39-0,4А но нет кина, так же PP5V_S0=0V
в форуме Apple
user54321
12 дек 2018, 15:40
user54321 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Apple A1534 (820-00045) артефакты, замерзание
в форуме Apple
user54321
2254
23 сен 2020, 11:38
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. A1534 EMC2746 (820-00045-10) Не видит встроеный SSD
в форуме Apple
isbonya
18
10147
05 авг 2018, 23:59
DENLOK Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook A1534 (820-00045-a) Найти разъем
в форуме Apple
radiolab
15 май 2017, 12:31
radiolab Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 20
