Alexcop писал(а):
по моим подсчетам при 3.3V это 1А потребление...
Подсветка питается от 19V. А вообще куча аналогов на вашу матрицу: 15,6" 1366x768 40 pin LED. PN: LP156WH2-TLFA
AU OPTRONICS: B156W02, B156XTN02 , B156XTN02.0, B156XTN02.1, B156XTN02.1 H/W:2A, B156XTN02.1 H/W:3A, B156XTN02.2, B156XTN02.4 H/W:0A, B156XW02, B156XW02 V.0, B156XW02 V.0 H/W:2A, B156XW02 V.0 H/W:AA, B156XW02 V.1, B156XW02 V.1 H/W:0B, B156XW02 V.1 H/W:DA, B156XW02 V.2, B156XW02 V.2 H/W:0B, B156XW02 V.2 H/W:4A, B156XW02 V.2 H/W:5A, B156XW02 V.3, B156XW02 V.6, B156XW02 V.6 H/W:0A; BOEHYNDIS: HT156WXB-100; CHI MEI: N156B6-L03, N156B6-L04, N156B6-L04 C1, N156B6-L06, N156B6-L06 C1, N156B6-L07, N156B6-L0A, N156B6-L0A A1, N156B6-L0A C1, N156B6-L0A C2, N156B6-L0A C3, N156B6-L0B, N156B6-L0B C1, N156B6-L0B C2, N156B6-L0B C3, N156BGE-L11, N156BGE-L11 C1, N156BGE-L11 C2, N156BGE-L21, N156BGE-L21 C1, N156BGE-L21 C2; CHUNGHWA: CLAA156WA11A, CLAA156WB11A, CLAA156WB11; INNOLUX: BT156GW01 V.1, BT156GW01 V.3, BT156GW01 V.4, BT156GW01 V.6, BT156GW02 V.0; LG PHILIPS: LP156WH2, LP156WH2-TLA1, LP156WH2-TLA2, LP156WH2-TLAA, LP156WH2-TLAB, LP156WH2-TLAC, LP156WH2-TLBA, LP156WH2-TLBB, LP156WH2-TLC1, LP156WH2-TLC2, LP156WH2-TLD1, LP156WH2-TLD2, LP156WH2-TLD3, LP156WH2-TLE1, LP156WH2-TLEA, LP156WH2-TLF1, LP156WH2-TLFA, LP156WH2-TLN1, LP156WH2-TLN2, LP156WH2-TLQ1, LP156WH2-TLQ2, LP156WH2-TLQA, LP156WH2-TLQB, LP156WH2-TLR1, LP156WH2-TLR2, LP156WH2-TLRA, LP156WH2-TLRB, LP156WH4, LP156WH4-TLA1, LP156WH4-TLB1, LP156WH4-TLC1, LP156WH4-TLC2, LP156WH4-TLD1, LP156WH4-TLD2, LP156WH4-TLN1, LP156WH4-TLP1, LP156WH4-TLQ1, LP156WH4-TLQ2, LP156WH4-TLR1, LP156WH4-TLRB; SAMSUNG: LTN156AT015, LTN156AT02, LTN156AT02-A02, LTN156AT02-A04, LTN156AT02-B04, LTN156AT02-C07, LTN156AT02-C10, LTN156AT02-D01, LTN156AT02-D03, LTN156AT02-D04, LTN156AT02-D09, LTN156AT02-L01, LTN156AT02-P01, LTN156AT02-P06, LTN156AT02-P08, LTN156AT02-P09, LTN156AT02-W01, LTN156AT03, LTN156AT03-001, LTN156AT03-H01, LTN156AT03-L01, LTN156AT05, LTN156AT05-001, LTN156AT05-301, LTN156AT05-701, LTN156AT05-F01, LTN156AT05-H01, LTN156AT05-H07, LTN156AT05-J01, LTN156AT05-S01, LTN156AT05-T01, LTN156AT05-U05, LTN156AT05-U09, LTN156AT05-W01, LTN156AT05-Y02, LTN156AT07, LTN156AT09, LTN156AT09-B02, LTN156AT09-H02, LTN156AT09-H04, LTN156AT10-503, LTN156AT13-K01, LTN156AT15, LTN156AT15-C01, LTN156AT15-C04, LTN156AT16-K01, LTN156AT16-L01, LTN156AT17, LTN156AT17-102, LTN156AT17-103, LTN156AT17-B01, LTN156AT17-D01, LTN156AT17-D02, LTN156AT21, LTN156AT23, LTN156AT23-C01, LTN156AT23-C02, LTN156AT23-W01, LTN156AT24, LTN156AT24-401, LTN156AT24-801, LTN156AT24-802, LTN156AT24-803, LTN156AT24-B01, LTN156AT24-C01, LTN156AT24-C02, LTN156AT24-H02, LTN156AT24-L01, LTN156AT24-P01, LTN156AT24-P02, LTN156AT24-T01, LTN156AT24-W01, LTN156AT27, LTN156AT27-302, LTN156AT27-B01, LTN156AT27-H02, LTN156AT27-H04, LTN156AT27-H07, LTN156AT27-W01, LTN156AT32; HYUNDAI: HB156WX1-100, HB156WX1-200; INFOVISION: M156NWR2 R.0
