Текущее время: 14 ноя 2026, 09:31
 Заголовок сообщения: Pavillion DV7 (DAUT1AMB6D0 REV:D) No hdmi, vga or lcd screen output
СообщениеДобавлено: 23 май 2017, 13:06
Pavillion DV7 DAUT1AMB6D0 REV:D
Hi,
I have 2 motherboards with the same behaviour, both load the operating system and have windows welcome sound, but can't see the image.
First thing I did was program bios chip with a known good dump.
One of them came at first with no boot problems and leds blinking, but after heating the northbridge softly, motherboard return to live.
I have change the northbridge, and now boots windows, but as explained above.
All voltages are good apparently, but northbridge has a few capacitors over its body that are short circuited. (zero ohms in the lowest ohms multimeter scale) (I think all of them are from +1.8V_VDDLT_18_NB supply)
The other motherboard has the same capacitors short circuited, but if heat the northbridge, then it boots normal and has a clear image on its lcd screen. (after removed the fan assembly, the capacitors are still short circuited)
I wonder if it is normal this behaviour of northbridge, but I have another similar motherboard, but UMA type with the same AMD northbridge chip , and over the same capacitors the readings are 883 ohms.
Need some advice in order to fix this motherboards.
Anyone faced a similar problem?
 Заголовок сообщения: Re: Pavillion DV7 (DAUT1AMB6D0 REV:D) No hdmi, vga or lcd screen output
СообщениеДобавлено: 24 май 2017, 07:41
It's normal.
СообщениеДобавлено: 24 май 2017, 14:28
Цитата:
It's normal.
Could you explain it a little?
Do you say that capacitors are short-circuited because there is some part damaged?
Or it is made this way by manufacturer, because this part of circuit is not in use? (I know that in the UMA motherboard it is in use, because it receives 1.8 volts.
Thanks for your answer.
СообщениеДобавлено: 24 май 2017, 15:23
Цитата:
It's normal.
:a_g_a: (for non-UMA)
СообщениеДобавлено: 24 май 2017, 20:24
I would like a better explanation,.
Anyone has a better answer, I mean more extensive, if it is possible.
Thanks.
СообщениеДобавлено: 25 май 2017, 02:22
If you remove northbridge, you will see,that this capistor not short circuted on it. Short circut on pcb, because this part of circuit is not in use.
В этой теме нет новых непрочитанных сообщений. Asus (n551jk rev2.0) No lcd, no hdmi video output
andromedax
2488
27 ноя 2019, 18:57
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP DV6 (Quanta R12) hdmi no output
andromedax
2506
30 сен 2018, 17:51
В этой теме нет новых непрочитанных сообщений. Giga N2060WF20C 6G hdmi not output
deathdealer9982
12 окт 2023, 17:51
ilie321 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Pavilion DV7 (DAUT1AMB6D0 REV:D) Не всегда включается.
INsaite
08 авг 2018, 14:51
В этой теме нет новых непрочитанных сообщений. Dell Insprion 7567 (bbv00/10 la-d993p rev 1.0) No screen, black screen.
в форуме Dell
anarasgarli
22 фев 2018, 13:23
anarasgarli Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot], Lokiro и гости: 105
