Заголовок сообщения: P5WS0 (la-6901p) no cpu core voltage
Добавлено: 01 июл 2017, 03:05
Зарегистрирован: 14 мар 2013, 00:33 Наличности на руках: 1.13 Сообщения: 106 Откуда: Ireland
Hi Laptop has black screen initially found +5vs to be 2.3v (bad cap), replaced now fan spins still black screen but still no +CPU_CORE voltage. PU12 vin is 19v Vdd is 5v VR_ON is 3.3v
Any help appreciated
MoneyBot
MoneyBot
morik59
Заголовок сообщения: Re: P5WS0 (la-6901p) no cpu core voltage
scobay
Добавлено: 01 июл 2017, 14:24
Hi +5vs is ok, the problem is there is no +CPU_Core voltage. I changed PU12 ISL95831CRZ-T also but still no out put from it. What else does it need in order to output +CPU_CORE?.
morik59
