Текущее время: 12 май 2024, 08:57
Внимание! Скачивание вложения в этом разделе стоит 10 Баллов.
Attention! Cost for attachment in this forum is 10 Points.
 Заголовок сообщения: Dell SE2416H -need help identifying a component
СообщениеДобавлено: 12 июл 2017, 17:18
I have a 10 days old Dell SE2416H with failed video board...Main processor had a dead short and it was replaced but i have i diode D110 blown which i can not identify...It is labeled as D110 but it has transistor markings B,C,E under the component...Component itself is blown but it is sot123 housing with marking WW* (* is the demaged place so i don`t know full marking ) Please take a look at photos...Any help would be appreciated...
 Заголовок сообщения: Re: Dell SE2416H -need help identifying a component
СообщениеДобавлено: 12 июл 2017, 17:36
Djosla, compare with D101.
СообщениеДобавлено: 12 июл 2017, 20:08
Ok...i took a risk and turned on monitor without diode...It worked ok but hdmi input was not detected...So i took measurments and i have concluded that missing diode was powering a U110 eeprom from U703 and 5v from hdmi connector (pins labeled B and E of D110,pin C goes straigt to 8 pin vcc of U110)...So i put BAT54C diode in place...I had to replace the U110 eeprom because it was also fried. 24c02 replaced with 24c04 and programmed with dump found here on vlab and voila...Works as it should...
Thanks...
В этой теме нет новых непрочитанных сообщений. Ideapad 110S-11IBR (NE116BW2_V1.0 PN: 431202920010) Help identifying a mosfet component
ablacon64
01 фев 2019, 12:17
recordsman Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Ah532 (Quanta Fh6) Need help identifying PU1
в форуме Fujitsu-Siemens
scobay
18 окт 2014, 09:32
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. help in identifying ci
TheMArcos
31 мар 2020, 04:43
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. help in identifying this vga
TheMArcos
23 апр 2020, 01:02
dennis85 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1060 Mini ITX OC 3G help with identifying a damaged chip.
allas
19 авг 2020, 10:27
allas Перейти к последнему сообщению
