Текущее время: 29 сен 2024, 01:31
 Заголовок сообщения: Lenovo g505 (La-99120) Not charging
СообщениеДобавлено: 05 авг 2017, 05:04
Motherboard is not charging battery, i have charged it in another laptop and it charges fine.
Charging Ic Bq24727.
Ac with battery present
pin 20 Vcc pin is 18.7v
Pin 12 Srn pin 11.9v
Pin 6 Acdet pin 2.8v
Pin 16 Regn is 6v
Pin 5 ACOK is 0v this is problem.
What is meant UVLO and what should it be ?.
Any help appreciated.
 Заголовок сообщения: Re: Lenovo g505 (La-99120) Not charging
СообщениеДобавлено: 05 авг 2017, 09:37
It is not a problem, ACOK is inverse on this charger
Undervoltage lockout comparator. This is the logical value of the VCC equal to about 3.75v, at which REGN LDO turns on.
You should check high-side power mosfet driver output
СообщениеДобавлено: 05 авг 2017, 13:40
HI this is confusing to me. This is from the spec sheet, is that not the opposite ??
5 ACOK AC adapter detection open drain output. It is pulled HIGH to external pull-up supply rail by external pull-up resistor when
voltage on ACDET pin is between 2.4V and 3.15V, and voltage on VCC is above UVLO and voltage on VCC pin is
275mV above voltage on SRN pin, indicating a valid adapter is present to start charge. If any one of the above
conditions can not meet, it is pulled LOW to GND by internal MOSFET. Connect a 10kΩ pull up resistor from ACOK to
the pull-up supply rail.
Also when you say "You should check high-side power mosfet driver output" what does that mean ? Pq301/302? or pq309?.
Thank you for the assistance
СообщениеДобавлено: 06 авг 2017, 03:47
pin 1-20v
pin 2-20v
Bq24727 readings
pin 5- 0v
pin 6-2.8v
pin 7-0v
pin 8-3.3v
pin 9-3.3v
pin 10-0v
pin 11-.49v
pin 12-11.8v
pin 13-11.8v
pin 14-0v
pin 15-.1v
pin 16-6v
pin 17-11.6v
pin 19-11.8v
pin 20-18.3v
When the laptop is off and battery is at 53% its only drawing .015ma
СообщениеДобавлено: 06 авг 2017, 22:34
pin 10 is actually 0.8v not 0v
СообщениеДобавлено: 07 авг 2017, 06:04
Also if boardview is available?.
СообщениеДобавлено: 08 авг 2017, 02:19
Any input appreciated
СообщениеДобавлено: 09 авг 2017, 22:38
I think - you have a problem with pq302. Check it.
You wrote:
check the measure on VIN, then 4pin of pq301, then P2, and P3
Профессиональный ремонт ноутбуков и моноблоков в Екатеринбурге, т. 372-23-60
СообщениеДобавлено: 11 авг 2017, 05:02
I meant to update the thread, it was actually faulty schottky diode Pd301. Replaced it then all working fine now.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenovo legion y540 (nm-c371) Not charging not switch on..
pcexpert8
29 дек 2022, 20:12
Yariy Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. E5-571 (LA-B161P) not charging not switch with battery
erdi34
06 окт 2018, 20:25
t.tashbaev Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo B580 (Intel) not charging
anf_andrei
09 окт 2014, 14:14
anf_andrei Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron 15 Gaming (LA-E992P) not charging
в форуме Dell
BalkanBoy
23 авг 2019, 21:52
BalkanBoy Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP PAVILION 15-P214DX (DAY11AMB6E0) Battery not Charging
abuholm
08 мар 2016, 02:46
ars44 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 42
cron
