Прошил flash дампом - "успешно" вернулся к цветным полосам.
UART дает следующее:
Цитата:
SPI jump setting is 3 bytes mode
Boot image offset: 0x10000. size: 0x50000. Booting Image .....
U-Boot 2013.01 (Dec 23 2015 - 12:33:06)
DRAM: 256 MiB
ROM CODE has enable I cache
SPI mode
SF: Got idcodes
00000000: c2 20 18 c2 . ..
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB
flash is 3byte mode
In: serial
Out: serial
Err: serial
AC: 332 HC: 249 P1: 996 P4: 996
C6: 664 DR:1328
J: 249 H1: 398 H2: 398
Net: GMAC set RMII mode
reset PHY
eth0
Warning: eth0 MAC addresses don't match:
Address in SROM is 4d:20:63:6f:6e:73
Address in environment is 00:42:70:00:30:22
Hit any key to stop autoboot: 0
start hdmi polling thread.
sli-hdmi is in 1920x1080 RGBI2C_IP1_init APB freq = 41500000
I2C_IP1_init: speed: 100000, div = 204
Please plug-in the HDMI cable, otherwise the system may keep wating the connection....
SF: Got idcodes
flash is 3byte mode
## Booting kernel from Legacy Image at 02000000 ...
Image Name: gm828x
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2853240 Bytes = 2.7 MiB
Load Address: 02000000
Entry Point: 02000040
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
: mem=256M gmmem=190M console=ttyS0,115200 user_debug=31 init=/squashfs_init root=/dev/mtdblock3 rootfstype=squashfs
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.3.0 (amos@ubuntu) (gcc version 4.4.0 20100318 (experimental) (Buildroot 2012.02) ) #72 PREEMPT Sat Jan 23 17:03:38 CST 2016
CPU: FA6 [66056262] revision 2 (ARMv5TE), cr=0000397f
CPU VIPT aliasing data cache, unknown instruction cache
Machine: Grain-Media GM828x series
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: mem=256M gmmem=190M console=ttyS0,115200 user_debug=31 init=/squashfs_init root=/dev/mtdblock3 rootfstype=squashfs
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total
Memory: 254024k/254024k available, 8120k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0x90800000 - 0xff000000 (1768 MB)
lowmem : 0x80000000 - 0x90000000 ( 256 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80537144 (5309 kB)
.init : 0x80538000 - 0x80554000 ( 112 kB)
.data : 0x80554000 - 0x805766e0 ( 138 kB)
.bss : 0x80576704 - 0x805b0704 ( 232 kB)
NR_IRQS:96
Timer use APB0 clock
gm_jiffies_init, system HZ: 100, pClk: 41500000
console [ttyS0] enabled
Calibrating delay loop... 660.68 BogoMIPS (lpj=3303424)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x3d6700 - 0x3d6748
devtmpfs: initialized
FMEM: 48640 pages(0xbe00000 bytes) from bank0 are reserved for Frammap.
FMEM: Logical memory ends up at 0x90000000, init_mm:0x80004000(0x4000), PAGE_OFFSET:0x80000000(0x0),
FMEM: FA726 Test and Debug Register: 0x0
NET: Registered protocol family 16
PMU: Mapped at 0xfe000000
IC: GM8286, version: 0x3
iotable: VA: 0xfe000000, PA: 0x99000000, Length: 4096
iotable: VA: 0xfe001000, PA: 0x98300000, Length: 4096
iotable: VA: 0xfe002000, PA: 0x98400000, Length: 4096
iotable: VA: 0xfe003000, PA: 0x98500000, Length: 4096
iotable: VA: 0xfe004000, PA: 0x98800000, Length: 4096
iotable: VA: 0xfe005000, PA: 0x99100000, Length: 4096
iotable: VA: 0xfe006000, PA: 0x96000000, Length: 4096
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource fttmr010:1
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Video Timer(timer3) Max 103000ms in 0xfec7b1a0 HZ.
ftdmac020 ftdmac020.0: DMA engine driver: irq 1, mapped at 0x90804000
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2. (NAND) б╘ 2001-2006 Red Hat, Inc.
msgmni has been set to 496
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
gpiochip_add: registered GPIOs 0 to 31 on device: ftgpio010.0
probe ftgpio010.0 OK, at 0x90862000
gpiochip_add: registered GPIOs 32 to 63 on device: ftgpio010.1
probe ftgpio010.1 OK, at 0x90864000
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0xfe001000 (irq = 9) is a 16550A
serial8250: ttyS1 at I/O 0xfe002000 (irq = 10) is a 16550A
brd: module loaded
loop: module loaded
FTSATA100_AHCI driver version 0.15
GM SATAPHY clock source : SATA0==SATA1, SATA1==PLL
GM SATAPHY Clock = 30 MHz
GM SATA0 config iSATA PHY setting
GM SATA0 PHY program i2c register offset 0x07, value=0x09
GM SATA0 PHY program i2c register offset 0x19, value=0x0c
GM SATA0 PHY program i2c register offset 0x35, value=0x10
GM SATA0 PHY program i2c register offset 0x36, value=0x80
GM SATA1 config iSATA PHY setting
GM SATA1 PHY program i2c register offset 0x07, value=0x09
GM SATA1 PHY program i2c register offset 0x19, value=0x0c
GM SATA1 PHY program i2c register offset 0x35, value=0x10
GM SATA1 PHY program i2c register offset 0x36, value=0x80
ahci ftsata100.0: forcing PORTS_IMPL to 0x1
ahci: SSS flag set, parallel bus scan disabled
ahci ftsata100.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ftsata100.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x93200000-0x93200fff] port 0x100 irq 28
ahci ftsata100.1: forcing PORTS_IMPL to 0x1
ata1: SATA link down (SStatus 0 SControl 310)
ahci ftsata100.1: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ftsata100.1: flags: ncq sntf stag pm led clo only pmp pio slum part ccc
scsi1 : ahci_platform
ata2: SATA max UDMA/133 mmio [mem 0x93300000-0x93300fff] port 0x100 irq 40
Not for NAND pin mux
SPI020 init
ftspi020 ftspi020.0: Faraday FTSPI020 Controller at 0x80300000(0x9086e000) irq 92.
spi spi0.0: setup: bpw 8 mode 0
CLK div field set 2, clock = 41500000Hz
ERASE SECTOR 64K
SPI_FLASH spi0.0: MX25L12845E (16384 Kbytes)
Creating 10 MTD partitions on "nor-flash":
0x000000000000-0x000000010000 : "NSBOOT"
0x000000010000-0x000000060000 : "UBOOT"
0x000000060000-0x000000400000 : "LINUX"
0x000000400000-0x000000700000 : "FS"
0x000000700000-0x000000800000 : "MTD"
0x000000800000-0x000000d00000 : "USER"
0x000000d00000-0x000000e80000 : "WEB"
0x000000e80000-0x000000fa0000 : "LOGO"
0x000000fa0000-0x000001000000 : "CUSTOM"
0x000000000000-0x000001000000 : "ALL"
Probe FTSPI020 SPI Controller at 0x80300000 (irq 92)
ftgmac: Loading version 2.0 ...
ftgmac: Tx queue number = 1024, Rx queue number = 512
ata2: SATA link down (SStatus 0 SControl 310)
ftgmac100-0-mdio: probed
ftgmac100-0 ftgmac100-0.0: eth0: 1 tx queue used (max: 2)
ftgmac100-0 ftgmac100-0.0: eth0: 1 rx queue used (max: 1)
ftgmac100-0 ftgmac100-0.0: eth0: irq 3, mapped at 90870000
ftgmac100-0 ftgmac100-0.0: eth0: generated random MAC address 92:31:20:a0:4a:30
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver ath9k_htc
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
FOTG2XX Controller Initialization
Enter Device A
Drive Vbus because of ID pin shows Device A
fotg210 fotg210.0: FOTG2XX
fotg210 fotg210.0: new USB bus registered, assigned bus number 1
fotg210 fotg210.0: irq 93, io mem 0x93000000
fotg210 fotg210.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Enter Device A
fotg210 fotg210.1: FOTG2XX
fotg210 fotg210.1: new USB bus registered, assigned bus number 2
fotg210 fotg210.1: irq 94, io mem 0x93100000
fotg210 fotg210.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
ftiic010 ftiic010.0: irq 18, mapped at 90876000
ftiic010 ftiic010.1: irq 53, mapped at 90878000
ftiic010 ftiic010.2: irq 50, mapped at 9087a000
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
devtmpfs: mounted
Freeing init memory: 112K
busybox: /linuxrc: Read-only file system
Mounting root fs rw ...
Mounting other filesystems ...
Setting hostname ...
Bringing up interfaces ...
/bin/sh: run-parts: not found
Mounting user's MTD partion
Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
empty_blocks 0, bad_blocks 0, c->nr_blocks 16
mount: mounting /dev/mtdblock4 on /opt/sav failed: Input/output error
mount: mounting /dev/mtdblock5 on /opt/app failed: Invalid argument
mount: mounting /dev/mtdblock6 on /opt/web failed: Invalid argument
mount: mounting /dev/mtdblock7 on /opt/logo failed: Invalid argument
mount: mounting /dev/mtdblock8 on /opt/custom failed: Invalid argument
sh: can't open '/opt/app/etc/boot.sh'
Что не может открыть? Тоже самое было до того как я испортил прошивку.
