Текущее время: 13 ноя 2026, 23:42
 Заголовок сообщения: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn
СообщениеДобавлено: 12 сен 2017, 12:56
Hi Im working on a DA0r76MB6D0 board no schematics only boardview available but using Quanta r7x schematics.
The unit was originally dead no adapter light no response from powerbutton.
Changed bios file but chip kept failing verification so changed bios chip and tried original bios ,same thing. Replaced sio same so tried different bios and board responds to powerbutton and only draws .2a and black screen, cpu gets warm. Laptop switches on by power button (draws .2a) but will not switch off again not matter how long the button is held.
Pl23 1.8v
pl21 0.8v
pl8 0.8v
Pl5 0.9v
pl9 2.2v
pl17 3.3v
pl18 5v
pl19 1.5v
kbc_rst 0v
mainon 3.3v
s5on 3.3v
dwbswon#3.3v
ec_rcin# 3.3v
kbc_p+3v 3.3v
vcore 3.3v
ecpwrok 3.3v
ecwrst 3.3v
APU_RST# 1.7v at R242
APU_PWRGD 1.8v
+0.95VS5 ok .95v
 Заголовок сообщения: Re: Hp15 (DA0r76MB6D0) Black screen, fan not spin .2a drawn
СообщениеДобавлено: 13 сен 2017, 13:25
kbc_rst 0v, а должен быть высоким. Его должен поднять HUB , или он мертв или что то не так.
kbc_rst 0v, and should be high. It should raise a HUB, or he's dead or something's wrong.
Пиши по делу, ибо внемлющие слововоблудию впадают в рукоблудие
СообщениеДобавлено: 13 сен 2017, 16:36
Hi yes but as there was a definite bios issue I didnt suspect the FCH to be faulty also , what conditions need to be present for FCh to output kbc_rst ?
СообщениеДобавлено: 13 сен 2017, 17:06
SUSB# , SUSС# ?
СообщениеДобавлено: 13 сен 2017, 21:01
seminenko писал(а):
SUSB# , SUSС# ?
Both are 3.3v after button press
СообщениеДобавлено: 14 сен 2017, 11:15
before that, the bridge must poll all the peripherals, LAN codec , Audio codec, cadrider, ets... and get on the bus response "ready", if one of them does not respond, reset will not rise.
I do not understand -draws .2a, is a monitor postkarte ? or...
СообщениеДобавлено: 14 сен 2017, 12:23
Draws .2a (200mah) as im using a bench supply so I can see how much current is being drawn. Is there a block diagram of this Apu available that will list the order the signal should be present in?
Posted after 35 minutes 27 seconds:
Apu is am50000ibj44hm. no FCH in this model.
СообщениеДобавлено: 14 сен 2017, 17:31
I'm sorry ,especially for you http://www.cpu-world.com/CPUs/Jaguar/AM ... -5000.html
Integrated peripherals / components
Integrated graphics GPU Type: Radeon HD 8330
Microarchitecture: Sea Islands
Shader cores: 128
Base frequency (MHz): 497
Memory controller The number of controllers: 1
Memory channels: 1
Channel width (bits): 64
Supported memory: DDR3-1600, DDR3L-1600
DIMMs per channel: up to 2
Maximum memory bandwidth (GB/s): 12.8
Other peripherals
PCI Express 2.0 interface (4 lanes)
Universal Video Decoder 4.2
Video Compression Engine 2.0 ?
High Definition Audio
SD controller
USB 3.0 controller
Serial ATA 3.0 controller
LPC bus
General Purpose I/O
---------- Добавлено спустя 3 минуты 12 секунд: ----------
I'll tell you more, this APU does not exist :hi_hi_hi:
СообщениеДобавлено: 14 сен 2017, 20:59
Im not sure what you mean?, here a pic of the chip on the board.
СообщениеДобавлено: 15 сен 2017, 11:51
на твоем фото am5000 а не am50000
on your photo am5000 not am50000
СообщениеДобавлено: 15 сен 2017, 20:29
Apologies I put 1 0 too many.
СообщениеДобавлено: 16 сен 2017, 11:09
back to the problem in the PCH chip is, it is a fact, the Condition for removing signal reset following
1. all power must be present.
2. The presence of RTC Clock and the SYSTEM Clock (check with oscilloscope with high impedance probe 1:10, or the touch of the probe to quench the generation and you'll see nothing)
3. System bus request is sent and response is returned on the readiness of peripheral devices.
If the bus is in doun (someone from the periphery dead, and does not give it up) will not be reset in the high state. From all written to be what you need postkarte and consistent removal of network codec, card reader , audio, USB3 and polec each operation to check the status of the reset and the presence postcodes. While all, good luck.
Сообщение не в тему
Pardon for my English, in school I was tortured by the French, but I can't remember
:du_ma_et: :-):
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Hp 540 g4 (X83) Black screen high fan spin
scobay
23 апр 2020, 00:31
scobay Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. hp8570p (Casper-UMA_CR_HPB) Switch on by itself and fan ruining full speed black screen
scobay
4280
03 мар 2020, 18:19
сергей петрович Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell XPS L502x (dagm6cmb8d) Fan constantly spinning full speed black screen
в форуме Dell
scobay
09 янв 2019, 18:24
В этой теме нет новых непрочитанных сообщений. Dell Insprion 7567 (bbv00/10 la-d993p rev 1.0) No screen, black screen.
в форуме Dell
anarasgarli
22 фев 2018, 13:23
anarasgarli Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus GL502VSK (GL502VS) no fan spin, no video, power and caps lock light
TheGiolly
07 сен 2019, 01:25
TheGiolly Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 128
