Зарегистрирован: 17 мар 2013, 14:22 Наличности на руках: 4.00 Сообщения: 203 Откуда: Ghana
Hi everyone, +3VA was shorted on the motherboard and diode D6005 happened to be the culprit. The part number on it is C96IH but google has produced no result. I will be very grateful if someone can help to identify the component or any substitute. Thanks.
Зарегистрирован: 15 мар 2014, 20:00 Наличности на руках: 162.63 Сообщения: 2228 Откуда: Morocco
TVL ST23 04 AD0
gofer писал(а):
TVL ST23 04 AD0
Thanks for the reply, I want to know if you have seen it on any particular board. Posted after 19 minutes 35 seconds: Just saw two of the ICs on a Toshiba motherboard (Manaus MN10R)
