Текущее время: 19 ноя 2026, 01:48
 Заголовок сообщения: Macbook Pro A1706 (Intel) ME File
СообщениеДобавлено: 01 мар 2018, 16:24
Hi, i need a file whith ME Clear for Macboo Pro Retina 13 inch A1706 EMC 3163.
Original file is missing, tested whith a dump from another machine works in slow motion.
Firmware version 11.6.14.1241
Consumer LP Rev: C0
SPT-LP Premium U
Thx.
 Заголовок сообщения: Re: Macbook Pro A1706 (Intel) ME File
СообщениеДобавлено: 01 мар 2018, 18:00
Its clean ME region 11.6.14.1241 from Win-raid repository pack
СообщениеДобавлено: 01 мар 2018, 18:15
Tested but not working, seems like i need some ME custom file made by Apple
СообщениеДобавлено: 01 мар 2018, 21:26
Whats the number of your apple board? 820-xxxx-a sample
Отправлено с моего iPhone используя Tapatalk
СообщениеДобавлено: 01 мар 2018, 21:37
Motherboard model 820-00923-A
СообщениеДобавлено: 02 мар 2018, 11:39
ok. You are using Intel CSME System Tools v11 r6 ?
You can try to use latest 11.8.50.3448_CON_LP_C0_NPDM_PRD_RGN
or try another dump
СообщениеДобавлено: 05 мар 2018, 15:44
Not working, original ME file have 1,168Mb,attached file have 2Mb
СообщениеДобавлено: 05 мар 2018, 15:56
Try here .
Incearca acolo. Tema nu este reinoita, dar este lucratoare.
Va costa niste bani, dar si platforma nu este jucarie, si EFI pierdut nu e o gluma.
СообщениеДобавлено: 02 июн 2018, 02:18
Hello. Does anyone have the files for A1706 EMC3163 820-00923-A that works and can share it here please?
With or without clean ME Region.
I know the ME region version is 11.6.14.1241 which I can download from Google but don't have the original EFI dump as the customer fry the chip. Not sure if the one posted above for board 820-00923-05 will work on this computer (820-00923-A) and cannot test it as the computer is with customer abroad.
Thanks in advance.
Posted after 9 minutes 42 seconds:
Actually now I can confirm that the firmware for 820-00923-05 will work on 820-00923-A but accordingly to the previous post the ME region 11.6.14.1241_SLM_LP_C0_NPDM_PRD_EXTR won't work. I believe it should as it has the same exact specifications. Maybe the previous user did some mistakes when he replace it. Does anyone else try this?
Posted after 1 hour 53 minutes 33 seconds:
I will try this ME region on A1706 EMC 3701 firmware, computer that I have and comes with 11.0.12.1010 which I already replaced it once from the Intel repository with success and all working fine.
If that will work then these ME firmware's are interchangeable and I can use 11.0.12.1010 on EMC 3136.
I will post update here.
I know is a lot of brain work here but worth a try as so far there is no solution anywhere online for this EMC 3136. I decide to work it out. I've done many of this "crazy" works before and with success in the end and I do not want to give up now.
СообщениеДобавлено: 09 окт 2018, 20:40
Замена ME в этой модели на новый или в новом дампе на родной - никак не влияют на скорость загрузки. Размер области ME - 1mb. Мне удалось удалить EFI пароль используя другой дамп, меняя блоки в настройках nvram. Теперь у меня другая проблема. Невозможно форматировать SSD. Диск защищен от записи и не форматируется. В систему загружается, но просит PIN 6 цифр. Даже не знаю, что делать.... Заливка другого дампа не решает проблему с SSD который распаян на плате.
СообщениеДобавлено: 11 окт 2018, 13:48
Сегодня удалось получить доступ к SSD распаянному на плате, сбросить защиту FileVault и форматировать его. MacBook pro retina 13 touch bar A1706 emc 3163 logic: 820-00923-A Полностью скорректирован EFI. Установлена чистая система и отвязан от icloud.
Что я понял из этой процедуры:
1. Чистый, грязный ME region никак не влияют на скорость загрузки
2. На скорость включения влияют настройки пользователя, UUID, логи ошибок, хранящиеся в EFI
Как нибудь напишу инструкцию и залью на обменник. Времени на аппарат много ушло, работы скопилось, надо раскидать.
СообщениеДобавлено: 27 ноя 2018, 12:51
How did you manage to reset the File Vault to access and Format the write protected SSD? By resetting PRAM ?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Macbook A1706 (Intel 7th gen) ME file
в форуме Apple
dany_l2003
3120
06 июн 2018, 16:34
lamo Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MacBook A1706 (820-00923) No S5 volltages on A1706
в форуме Apple
abuholm
03 июл 2021, 04:50
abuholm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A1706 (A1706) Flexgate.
в форуме Apple
klokol
01 сен 2020, 13:59
Lexnay Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. The BIOS downloaded from GIGABYTE's official website is an .exe file. How can I convert it into a bin file for
в форуме Беседка
dianzi
11
1386
05 окт 2025, 19:22
dianzi Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro (13-inch, 2016, Four Thunderbolt 3 Ports) A1706 EMC3071 (820-00239-A) Восстанавливаем водолаза
в форуме Apple
Aeronaut
5518
25 ноя 2019, 15:39
Dem@ns Перейти к последнему сообщению
