Текущее время: 22 ноя 2024, 13:38
 Заголовок сообщения: HP CQ57 ( FOXCONN CHICAGO) caps lock blinking +VGFX_CORE missing
СообщениеДобавлено: 05 мар 2018, 01:37
Hi,
The problem seems similar as in topic: http://vlab.su/viewtopic.php?f=53&t=35673
CPU and memory are tested, ec-bios and pch-bios reprogramed with tested dumps.
The power sequence is ok except step 12. (IMVP_PWRGD is not present due to +VGFX_CORE missing)
PLT_RST# (step 15) is reached, 3 volts are present, so power sequence seems to be ok.
There are no pulses PCH_SMB_CLK_3S and PCH_SMB_DAT_3S, both are high level. (same for PCH_SMB_CLK_3A/PCH_SMB_DAT_3A)
Debug card does not function on this board, so can't test debug codes.
Can someone help me to solve the problem?
Thanks.
 Заголовок сообщения: Re: HP CQ57 ( FOXCONN CHICAGO) caps lock blinking +VGFX_CORE missing
СообщениеДобавлено: 05 мар 2018, 10:44
andromedax писал(а):
step 12
this step will pass when CPU programm says that all powers good and after that you arrive +VGFX_CORE/ CPU says that all ok when will check multicontroller and south bridge. so last part must be changed/
let me your board revision?
не будьте дампоепами...
СообщениеДобавлено: 05 мар 2018, 13:11
Hi, thanks for your help.
It is difficult to say the revision number, it has no motherboard number like other HP.
The attached schematic seems to match perfectly.
I've attached also a photo from memory slots that says something about revision.
I think south bridge is the culprit, but i wanted to know other opinions before change it.
Do you think the power-up sequence is completed when PLT_RST# is high level?
 ! igils писал(а):
II. General Forum Rules:
10 . To download the schemes and any other files which are already in the forum is forbidden.
12. To attach schemes to the messages is forbidden. For this purpose there is the appropriate theme in each subsection of the specific producer.
СообщениеДобавлено: 06 мар 2018, 13:41
Hi, some updated tests:
I have re-reprogramed bios with new dump from sp54776.exe. (extracted from this file)
There are tre versions inside this file, and I think the $BID03672 is valid for this this mobo. (its the same as the original one, but the serial number in original bios doesn't match the laptop serial number)
So next thing to do is check two other versions inside sp54776.exe ($BID03674 and $BID03676)
I have checked the behavior without pch-bios chip, and PLT_RST# is always at low level, and laptop starts and then stops and repeats as long it is connected.
Power (amps) consumption from 19v. are only 450 mA. (with bios chip)
Posted after 23 minutes 51 second:
Sorry, i wanted to clarify witch schematic i was using, but as rules say, I had to write the link of it in the forum.
For the same purpose this screen capture is also valid:
В этой теме нет новых непрочитанных сообщений. CQ57 (Foxconn Chicago) Калится TPS51123
RavD
17 дек 2015, 14:00
RavD Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Hp compal CQ57-400ER (AMD Brazos) Мигает caps lock 6 раз.
pavlenkoart7
21 окт 2022, 13:18
pavlenkoart7 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. X54H MB Ver.:K54HR - SX0022D (K54LY REV. 2.1) Авто запуск, нет видео горят индикаторы Num Lock и Caps Lock
eldorado
12
8190
20 май 2017, 15:46
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP6320 (chicago) HP 630 (CHICAGO-CP-HPC-MV-MB-V2)
spaol
25 фев 2016, 15:21
joey:) Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP cq57-410er (chicago-hr-hpc) Не могу декодировать апдейт 03672.fd
bvd
19 фев 2015, 19:51
bvd Перейти к последнему сообщению
Сейчас этот форум просматривают: alev, bars_net, i001546, shur1y, StayeR, wentel6, Yandex [BOT] и гости: 111
