Текущее время: 28 ноя 2026, 05:38
 Заголовок сообщения: Lenovo Thinkpad Yoga 14 /s3/ (Wistron LCB-1 13323) Can't turn on on battery only.
СообщениеДобавлено: 20 мар 2018, 13:59
Hello everybody.
I have a problem with this notebook - can't turn on on battery only. When charger is plug in, notebook starts normally, Windows loading and everything looks fine. Battery status is '100% charged'. But when disconnect power adapter, notebooks turns off. There is a small I/O board for dc jack, battery jack, usb, etc. I/O board connects to motherboard with cable.
What I did:
- think charger issue. replace charger - no result.
- connect power adapter - 20v present.
- connect battery - 15v present on pin 6,7 /last 2 pins/, but these 15V not present on connector from the I/O board to motherboard.
I can't find schematic for this board, if someone can help, I will buy a beer :)
I/O board attached to post.
Thanks.
 Заголовок сообщения: Re: Lenovo Thinkpad Yoga 14 /s3/ (Wistron LCB-1 13323) Can't turn on on battery only.
СообщениеДобавлено: 21 мар 2018, 12:46
Measure the resistance of the battery connector to ground with the power supply disconnected
СообщениеДобавлено: 27 мар 2018, 17:51
Sorry for delay, have work outside office.
pin 1 - 2 ohms -> ground
pin 2 - 2 ohms -> ground
pin 3 - 630 kilo ohms
pin 4 - 67.5 kilo ohms
pin 5 - 73 kilo ohms
pin 6 - 147 kilo ohms
pin 7 - 850 kilo ohms
СообщениеДобавлено: 03 апр 2018, 18:08
Anyone with advice? Thanks.
СообщениеДобавлено: 04 апр 2018, 16:55
I think I found the problem, but I can't read marking code. Position on IO board - PQ502 3 pin transistor /maybe/.
СообщениеДобавлено: 06 апр 2018, 13:06
Problem solved - PQ502 - there is no 15 volts /battery voltage/ after it.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Yoga 14 (LCB-1 13323) ищется биос дамп
btomce
13 мар 2017, 00:06
В этой теме нет новых непрочитанных сообщений. lenovo yoga 14 (lcb-1 mb 13323-2) Нужен серийный номер с такого же ноутбука
oki4w
17 дек 2020, 03:30
oki4w Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo Yoga LCB-1 MB 13323-2 448.01127.0021 ищу дамп мультиконтроллера
в форуме Поиск BIOS
Pauk
19 дек 2023, 00:14
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Yoga 14 (LCB-1) Висит на заставке BIOS
nismo555
2650
04 авг 2018, 16:07
nismo555 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo IdeaPad 320 (Intel) Lenovo IdeaPad 320 can't turn on
cygron
29 май 2021, 13:32
cygron Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot] и гости: 87
