Текущее время: 26 июн 2024, 10:12
 Заголовок сообщения: MSI R7 370 - help in diagnose and so on
СообщениеДобавлено: 21 июл 2018, 12:03
MSI R7 370 2GB - help in diagnose and so on
Hello every one.
I have decided to write on this forum because I hope you can help me solve problem with my graphic card. I have to stress that electronics is not my profession yet. However, I keep try to learn it.
Diagnostic: The computer starts correctly, but the screen is black. Computer doesn't see card (it was verified using second graphic card).
Measured resistance:
SFC x4 (probably power supply of gpu) 0ohm
SFCx1 (probably power supply of memory) 25 ohm
1RO (probably gpu controller) 68 ohm
2R2 (probably memory controller) 107 ohm
LR47 (probably pci express or it is only 12 line) it starts from 0 and increase slowly to 4k ohm
Electric potential:
SFC x4 about 0V
SFCx1 about 0V
1RO about 0V
2R2 about 0V
LR47 12V
Moreover I have measured resistance for MOSFET (left side form power of GPU) and it looks fine.
First 3 (from top) are the same: G1 is about 8,8 ohms and G2 is about 74 ohms.
Last one is inverted by 180 degrees and G1 is about 8 ohms and G2 is about 40 ohms
The resistance was marked on the photo.
I haven't got idea what I should check now.
I have second one graphic card. It is that same, but 4GB memory. There I have some misses components.
C2610, C2507 and c2506 (I have tried to desolider this one but it crashed). I know that it is a capacitor 0201 but I dont know it values. I think that they are the same. Mabye someone know capacitance and voltage (I think that voltage is 10V)?
At the end if you preffer you could answer in you official language I will translate it.
 Заголовок сообщения: Re: MSI R7 370 - help in diagnose and so on
СообщениеДобавлено: 22 июл 2018, 12:30
zero ohm on gpu supply is VERY low. you must to remove inductors, and find reason of short citcuit (dc-dc or gpu, also you may have some capacitors shorted)
В этой теме нет новых непрочитанных сообщений. Diagnose fault with MSI GTX 970 4GD5T OC fan tachometer
MSIGamer72
07 мар 2021, 00:39
MSIGamer72 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Msi R7 370 2g armor turns on and off 2 seconds later
TheMArcos
1608
10 май 2020, 20:16
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. help for asus x552e (help for asus x552e) help
serwanjaf7
05 авг 2016, 18:08
serwanjaf7 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help help Help memory samsung detect micron (domate)
PT-AH
02 ноя 2022, 14:43
PT-AH Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony SVE1511C5E (Quanta HK5, MBX-269 REV-F) Looping On and Off and No video on LCD
в форуме Sony
mun4o
05 мар 2015, 19:39
mun4o Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot], neo26rus и гости: 26
